Hey guys. It hurts having to make this post but I'm experiencing problems with my vespa. My Vespa was not being used for over a month as I was travelling. When I tried to use it again, it was simply not starting despite the cranking. I experienced this a few times in the cold, but on this particular occasion it felt hopeless. I thought this could be the battery, however all the lights seem to light up properly (though I'm yet to test the battery properly). A day later I gave it another go, and as the engine was cranking, I was smelling a lot of fuel. Eventually I noticed a fluid dripping on the ground, which might be fuel. I then had a look at the engine as I attempted to start up the scooter and I captured this fluid spewing out of some pipe. Now I'm not sure if this is directly related to the engine not starting, but it seems like a serious problem.
Here is a video of the fluid/fuel: https://streamable.com/5gjd0x
I'm pretty new with vespa so I'm quite clueless, as you may already tell.
I have a vespa LX 50 from 2013. It has around 13,000km.
I'd appreciate any help!
