@nelluch125 avatar
1981 Vespa P200e, 1985 Vespa PX125e, 1985 T5, 1971 Sprint Veloce
@nelluch125 avatar
So I have px125e.
Swapped in a p200 engine.
All lights work minus the headlight (top bulb) and the horn.
When I start flipping switches, the bottom light turns off and the large bulb lights up bit only when i rev the throttle. It's nothing noteworthy but it does light up a tad.
The horn gives me nothing. It's dead.
Any idea what I could be?
Could it be the bulb?
Do I need a new horn?
Could it be the rectifier?
Any tests I can do to narrow it down?
The battery is brand new.
Thank you.
N
@garncarz avatar
@garncarz avatar
@nelluch125 avatar
@nelluch125 avatar
garncarz wrote:
https://www.scooterhelp.com/electrics/pages/VNX2T.px125e.html
https://www.scooterhelp.com/electrics/pages/VSX1T.p200.html
Grounds are good. Switches intact.
@chandlerman avatar
Innovator
301 Days Since Last Explosion
Innovator
@chandlerman avatar
Isn't it a split AC/DC system? Sounds like something is crossing over between the DC (pilot light/turn signals/brake light) and AC (headlight/tail light) sides of the electrical system, maybe.
@nelluch125 avatar
@nelluch125 avatar
I have no idea.
Electrical issues elude me. I am honestly at a loss. Hence why I'm here asking. I'm hopeful someone has experienced this and solved it.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
yeah headlight and horn are on the ac side of things
@nelluch125 avatar
@nelluch125 avatar
Ok. So what does that mean in respect to diagnosing or resolving my issue?
PX150E
PX150E
When you swapped to the P200 engine, did you transfer the stator from your 125E to the 200? I am pretty sure you need that stator for everything to work properly as before. The battery powers the horn, brake light, neutral light, and tail light (if your ignition switch has a parking position).
@garncarz avatar
@garncarz avatar
@nelluch125 avatar
@nelluch125 avatar
I installed the stator that came with the p2.
Everything works. Minus the horn and tip headlight bulb.
@spacecat avatar
Vespa Primavera 1974
@spacecat avatar
Take these two items out and test them separately. They may both have failed or they may have different causes of failure.
[ Time: 0.0103s ][ Queries: 4 (0.0035s) ][ live ][ 343 ][ ThingOne ]
