Hi all!
I have a new-to-me 2015 GTS Super. It's my first modern Vespa after riding a P200E for years. For the first couple weeks, it worked like a dream.
Then I rode it to work one day, left the keys in the ignition, and completely drained the battery. I tried trickle charging for a few hours and got it to turn over and stutter like it wanted to start but not quite. I then tried jump starting it off a car to no avail, so I pulled the battery and trickle charged it overnight until it was holding a charge of 13.2 volts while being charged.
After reinstalling the charged battery, it turns over the engine but I still can't get the scoot to start.
Things I've checked:
— I hear the fuel pump prime for two seconds when I turn on the ignition;
— the battery shows 12.65 volts in a resting state and about 11.4 volts under load.
— when I depress the brake and the starter, the starter motor turns over for about 10 seconds but there's no stuttering or other signs that the engine is going to start.
— when I turn on the ignition, the immobilizer light flashes once for less than a second and then stays off. (I've also tried testing reprogramming the keys with the brown master. If I only program one key, the unprogrammed key wont turn over the engine, and after the first flash the red immobilizer light stays on, whereas the immobilizer light flashes once and then stays off off if I use the programmed key, which also is able to turn over the engine. When I program both keys, they're both recognized and can turn over the engine.)
— I've tried starting the engine with the brown master key. I get the same .7 second flash, followed by quick flashes for the number of keys programmed, and then the light stays off. If I pull out the chip, then the light stays on.
— I have spark. (When I removed the plug to test it, it had a bit of carbon deposit on the side electrodes, which I cleaned off.)
— All the fuses in the glove box have continuity, which I visually inspected and tested with a multimeter.
— the Vespa has a full tank of fresh gas
— I've tried holding down the left brake handle, the right brake handle, and both brake handles while pressing the starter. Both brake handles activate the rear brake light.
— the previous owner removed the side stand. I don't believe the side stand had a safety switch on this model in any event.
— the front headlight doesn't come on when I turn on the ignition, but I'm not sure whether this is normal (and it only turns on when it starts).
— The oil light and ABS light stay on, which I think is normal since I took the battery out.
I'm at a loss here. Any ideas of what I should check next or what could be causing the issue? I can post a video of the Vespa turning over when I try to start it if that would help.
Thanks!
