@autojack avatar
'76 Vespa Rally 200
@autojack avatar
'76 Vespa Rally 200
I've never been that diligent about cosmetic care of my scooter. It was pretty battle-scarred when I got it in 2009. I don't even wash it very often.
At one point I replaced the headlight bezel and mirrors. As you can see, they have corroded pretty badly since then. I assume the chrome is beyond hope. Maybe I should replace these again and take better care of them next time.
I was thinking about going over the paint, maybe doing a clay bar, polish, etc. But I'm not sure if it would do more harm than good. Any thoughts?
@garncarz avatar
@garncarz avatar
@zachyzach avatar
@zachyzach avatar
Did I read one time about using aluminum foil and water to rub out old hazy or rusty chrome bits? Been meaning to try...
@langolson avatar
Vespa 125 VMA, Vespa SS 180
@langolson avatar
^^ Yes, this works surprisingly well. Crumple up the aluminum foil, dip it in water and start rubbing. The chrome will look like new.
@spacecat avatar
Vespa Primavera 1974
@spacecat avatar
On this tip, how do you protect the chrome after? Wax or clear coat? I may get around to doing my luggage rack.
@zachyzach avatar
@zachyzach avatar
Between those two, I'd vote for wax if anything. It's harmless to vintage scoot/auto paint surfaces and re-applicable whenever needed. This has been used with great results, and would think it's fine on chrome if used gently. On warm days, it's easy to apply and wipe off again as it's much softer:
@langolson avatar
@langolson avatar
After cleaning it up with the aluminum foil, I use chrome polish. It says it protects the chrome…
@qascooter avatar
@qascooter avatar
Here is what I use. And I do the same as grancanz...
The trio of cleaning/protection
And Mother's for the mirrors and chrome
[ Time: 0.0112s ][ Queries: 4 (0.0048s) ][ live ][ 343 ][ ThingOne ]
