@sadragna avatar
GTS SUPER 300
@sadragna avatar
GTS SUPER 300
I have a 2023 GTS 300 super I set the clock after I took delivery bc the time was off. I noticed now the clock is off again. Any idea why it jumps 8 minutes off. I do have a theory that the government controls the time with anything connected to the internet.
Vespa GTS 300
Vespa GTS 300
Sadragna wrote:
I do have a theory that the government controls the time Facepalm emoticon with anything connected to the internet.
Delusions of persecution? Paranoia? Conspiracy theory?
Does anyone know if a Tinfoil hat will fit in the helmet compartment?
Fun?! Laughing emoticon ROFL emoticon
The instruction manual will help:
"MENU SETTINGS.
With the vehicle stationary, briefly press the joystick to the left to display the "SETTING MENU" function in the Infopanel.
Press the joystick to the right for a long time to enter the menu.
Press the joystick briefly up or down to highlight the desired function, press the joystick briefly in the middle to select:
LANGUAGE
CLOCK
UNITS
PAIRING
BACKLIGHT (BACKLIGHT)
SETTING THE CLOCK
The clock is automatically set when the "Vespa MIA" device is connected.
To set the clock manually, proceed as follows:
Press the joystick up or down briefly to set the desired hours and minutes. By pressing the joystick for a long time, the numbers will change continuously.
Confirm by pressing the joystick briefly in the middle.
As soon as the selection is confirmed, the display shows the next submenu UNITS.
If more than 5 seconds pass without a selection being made, the display changes to the selection of the CLOCK submenu.
WARNING
FOR SAFETY REASONS, THE CLOCK SETTING CAN ONLY BE MADE WHEN THE VEHICLE IS STATIONARY."
2019 GTS 300 HPE SuperTech 71,000km
GermanGTSDriver wrote:
[quoting from the manual]
Not sure with the iPhone app but i wouldn't be so confident with the Android app
A Vespa is a premium device. Are you sure it's the Vespa that's wrong and not all your other clocks?
If you're a true blue Vespa rider you should live your life in Vespa time regardless.
@sadragna avatar
GTS SUPER 300
@sadragna avatar
GTS SUPER 300
"MENU SETTINGS.
LANGUAGE
CLOCK
UNITS
PAIRING
SETTING THE CLOCK
WARNING
I've done this a few time to match what ever time is on my phone. I understand 1-2 minutes different fine but when it get 8-10 minute difference I start to wonder if there might be something wrong.
Vespa GTS 300
Vespa GTS 300
I have never heard of this phenomenon. There is nothing about it in the German forum either. If this understandably annoys you, talk to your dealer.
@sadragna avatar
GTS SUPER 300
@sadragna avatar
GTS SUPER 300
I was going to do that when it goes in for its first service
The clock on my Supertech never held correct time until I implement a clock sync on my own app.
@sadragna avatar
GTS SUPER 300
@sadragna avatar
GTS SUPER 300
I have a super GTS so the app won't work for me.
@giallo avatar
GTS 300 hpe
@giallo avatar
GTS 300 hpe
Even digital clocks drift over time. Nothing to be overly concerned about. My GTS clock drifted by a few minutes over two years.
https://en.m.wikipedia.org/wiki/Clock_drift
@der_blechfahrer avatar
It is real and it is annoying. I reset my clock last week as it was off by 30 minutes. Last time I set it before was when we changed to summer time. The android Mia app definitely does not set the time.
I can understand why people get cross with the digital clocks drifting on Piaggios. There's no excuse for it, as temperature changes etc affect stick-on digital watches just as much if not more, and *they* don't drift like that.
[huge generalisation alert] Italians don't seem to be that bothered about time in the first place, so maybe none of their QA engineers over the years ever spotted the errors. [/alert]
@giallo avatar
GTS 300 hpe
@giallo avatar
GTS 300 hpe
I find myself also completely unbothered by the drifting clock. I did notice it, but have not until now ever given it any thoughts. But then I am the kind of person that doesn't always set my PTW clock an hour back in the fall.
After all, I go for rides to escape things like precise time keeping and stretch distances that I could cover in a short time into something that gives me pleasure for a good chunk of my day.
@giallo avatar
GTS 300 hpe
@giallo avatar
GTS 300 hpe
Add on: my car clock drifts as well and strangely does worse when I set it to synchronize via GPS. It's not only Piaggio and it's okay.
@bluside avatar
2020 GTS 300, 2011 LX150ie
@bluside avatar
I'm in the camp where if it's going to have a clock, it should show the correct time.
The blank clock on my LX drove me crazy until I was able to change the battery.
@sadragna avatar
GTS SUPER 300
@sadragna avatar
GTS SUPER 300
I don't mind the drifting 1-2 minutes but when it's 10 plus minutes ahead and you think you're running late but you had plenty of time. Also setting the clock every few days is getting annoying.
Take the battery out and add a stick-on cheapo digital watch.
I use my $13 Casio watches when the straps break - as new straps are almost as much as the watch was in the first place.
I'm talking a couple of minutes a week not per year
@giallo avatar
GTS 300 hpe
@giallo avatar
GTS 300 hpe
I understand that. It still would not concern me much, setting a clock is easy and Vespas are not the only vehicles that have clocks that aren't always accurate. Hondas have had this problem for a while: https://www.ctvnews.ca/mobile/business/honda-investigating-potential-problem-with-clock-displays-in-some-cars-1.5731019
Also: my Vespa is my first PTW that even has a built in clock, I can't say that I ever missed that feature on a motorcycle before.
⚠️ Last edited by giallo on UTC; edited 1 time
I don't think there's a separate clock battery anymore. But you can bring up the trip time instead of the clock.
@sadragna avatar
GTS SUPER 300
@sadragna avatar
GTS SUPER 300
I adjusted my clock 4 days ago and made it 2 minutes behind what ever my iPhone was showing. I wanted to see if maybe I adjusted it wrong in the passed but sure enough today it was 3 minutes ahead of my iPhone.
@theoldsquid avatar
250gts ie
@theoldsquid avatar
250gts ie
My Honda CBR had a clock that I could navigate by! My 06 GTS was worthless and I do like a good clock as I live on an island and need to catch a ferry to get off. I'll check my new 23 and see if it's holding better time. A time module should be accurate to a few seconds a week!
@sadragna avatar
GTS SUPER 300
@sadragna avatar
GTS SUPER 300
So I have to adjust the clock every 3 days. By day 3 it's 15+ minutes ahead.
[ Time: 0.0217s ][ Queries: 4 (0.0150s) ][ live ][ 334 ][ ThingOne ]
