@reggie1906 avatar
MP3 500
@reggie1906 avatar
MP3 500
I know that this has been discussed several times, but I can't find anything specific to the 2019 MP3. Can I upgrade the headlights, what is the recommended highlight, and can I upgrade the high beam as well? Any information would be greatly appreciated!
2015 MP3 500 ie Business
For the low beam, this OSRAM is pretty much the sole true plug and play solution available as it this the only that fits within the housing. This is the one myself and a couple of other forum members use
https://www.osram.com/ecat/LEDriving%20HL%20H7%20Gen2-LEDriving%20HL-LED%20high%20and%20low%20beam%20lamps-Car%20lighting-Automotive/com/en/GPS01_3143582/ZMP_4059095/
As for the high beam, that one is more difficult since Piaggio uses a proprietary connector. You can try this one, but you'll find that light output will likely be poor along with a short service life.
https://www.osram.com/ecat/LEDriving%20HL%20EASY%20H7-H18-LEDriving%20HL%20EASY-LED%20high%20and%20low%20beam%20lamps-Car%20lighting-Automotive/com/en/GPS01_3836534/ZMP_4063386/
@reggie1906 avatar
MP3 500
@reggie1906 avatar
MP3 500
Thank you for pointing me in the right direction!
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
replace the mirrors inside the unit for H4 better option and yes the system can take it look at de Older MP3 500 / Gilera Fuoco it got 4 headlights
When i do a conversion i will glue in H4 mirrors in to the older H1/H7 mirrors so you are able to adjust the light as normal with the adjustment screws
there is a how to here some wher i've done years ago H1/h4 problem solved or something like that can find it right now have to many threads made Razz emoticon
[ Time: 0.0094s ][ Queries: 3 (0.0028s) ][ live ][ 343 ][ ThingOne ]
