I'm having a curious issue that I hope someone can help me with.
I have a 2003 ET4 150 my niece got for a bargain basement price and, of course I got selected to make it run.
Previuos owner claims it was running a year ago when they put into storage.
All my wrenching experience is with a PX150 2 stroke and the ET4 is a little bit different (actually quite a bit different).
I replaced the battery (which would not hold a charge) and now I can get it to turn over and and fire up if I spray carb cleaner into the air box.
So it seems there may be a fuel feed issue.
The tap is a vacuum controlled one and I think that is where the problem lies.
It looks like it's been leaking so I have ordered a replacement but I will need to figure out if it is connected properly.
There are 2 hose attachments on the tap (other than the big one that goes into the tank).
The top hose is cut off and plugged.
The bottom hose connects to the left side of the manifold.
If I pull this hose off of the manifold no gas comes out (yes, I did put gas in the tank).
The hose on the right side of the manifold is cut off and plugged.
Shouldn't there be a fuel line that goes to the carb so gas is mixed with air before the manifold?
Isn't that the point of having a carb?
This seems to be a very strange arrangement and I really don't understand how it could run with the hoses like this.
