Few pics...
![]() 1979 P150X, 1983 P200E, 1987 PK125XL Elestart, 1988 T5, 1995 PX200E, 2011 Yamaha Fazer 600 S2
Posts: 4644 Location: Veria, Greece |
One more smallie getting prepped for a friend and club member. He already owns a GTS 300 Super but wanted something older and definitely a smallframe. He found one with papers, freshly resprayed but was terrible up close. He decided for a full resto and some upgrades. We're going 125cc and also the front end from my blue PK. We had it blasted a while back and now we're working on the frame. New complete legshield and some patches on rotten areas...
Few pics... ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Positive
![]() Polaris Grey Rally 200, Blue Marine Primavera ET3, Coral Red 50 Special
Posts: 468 Location: Melbourne |
Did you use that concrete saw to chop down the panels?
The rust on the inside of the tunnel is always out of sight out of mind unless you take the frame down this far. |
Time for an update. Progress with the frame. Grabor legshield is a bit crap and was misaligned. Had to make some mods to bring it where it should be. The one from SIP I had bought for our "Special" was way better...
Positive
Johnny Two Tone
![]() '15 GTS300, '86 PX125EFL, '66 VBB, '01 ET4
Posts: 9018 Location: San Diego, CA |
You make it look easy, but I bet it's a real bitch to get that to all line up. Bet that legshield comes out of the stamper as straight as a potato chip.
Positive
![]() '64 Motovespa 150S (177) , '65 VBB, '66 Allstate SF, '66 180SS, '58 LD 125 (150)
Posts: 2102 Location: S.Salem, NY |
sdjohn wrote: you welding types always impress me with the metal work. ![]() |
Johnny Two Tone
Moto64 wrote: I think it's the most satisfying and the most fun part. Painting is all anxiety. Metal work - I just can't go there yet, not welder and no skills. Will pass on projects that need this type of help in favor of those that don't. |
![]() Wrecked '61 VNB '65 Allstate '74 Rally 200
Posts: 1916 Location: PNW |
whodatschrome wrote: You're doing the Lord's work Safis I'm pretty much in awe of OP's project skills ![]()
Positive
![]() VNB VSC VMA VSX - o9c vmb vse
Posts: 9097 Location: Hustletown, TX |
macgerk77 wrote: +1 I'm pretty much in awe of OP's project skills ![]() Anyone doing welding and fabrication work. *doffs cap*
Positive
![]() UTC
Nedminder
Posts: 4173 Location: california |
Nedminder
![]() 62 VBB1T Round Tail W/ leaner sidecar
Thanks Gents!
orwell84 wrote: You make it look easy, but I bet it's a real bitch to get that to all line up. Bet that legshield comes out of the stamper as straight as a potato chip. ![]() ![]() Last time I buy anything Grabor made. They stamped it off center, about 3mm. Foot brake holes don't align with the tunnel so I have to move them and the lip where the legshield trim goes on, is wider on one side (needs trimming)… charlieman22 wrote: Safis - is that a "rust converter" paint, or a "weld through primer" or both? |
![]() UTC
Nedminder
Nedminder
Looks great.
Thing is going to look brand new when done. Offset holes due to bad stamping: ![]() Why did they even bother to stamp it... What a pain. |
![]() UTC
Innovator
Posts: 11131 Location: Nashville 10 Days Since Last Explosion |
Innovator
![]() 76 Sprint V, 63 GL, 62 VBB, 05 Stella, 66 Smallstate, 66 Lammy S3
Love the work and especially the documentation via photos, SaFis!
When I eventually make the Smallstate pretty, it'll get a new floorboard, but not a full legshield, I don't think. Seeing how this stuff is done is hugely educational for me, not to mention impressive as hell to watch happen. |
SaFiS wrote: It was a PITA. Potato chips are straighter.. ![]() ![]() Last time I buy anything Grabor made. They stamped it off center, about 3mm. Foot brake holes don't align with the tunnel so I have to move them and the lip where the legshield trim goes on, is wider on one side (needs trimming)… I like your use of screws. |
Small update. Made a brace for the legshield, something that Piaggio should have added from the factory...
![]() ![]() ![]() ![]() Moto64 wrote: Quality control was on vacation ? Crap made by Grabor
Positive
![]() UTC
Innovator
Innovator
SaFiS wrote: Small update. Made a brace for the legshield, something that Piaggio should have added from the factory... |
Finished today with everything welding related. I also used solder on the seams of the nose to avoid as much bondo as possible during prep for paint...
Positive
A bit more progress on the smallie. Shortened PK fork, drilling for the rails and a lot more things to do...
Positive
![]() '13 LML Star 200, '81 50 Special, '81 P 150 X, '87 PK 50 Nuova, '84 PK 50 S
Posts: 1502 Location: Ukraine. Kyiv. |
![]() 74 Super, 75 Super, PX project, LML off-roader and '66 Blue Badge Smallframe
Posts: 8959 Location: Victoria, Australia |
SaFiS wrote: A bit more progress on the smallie. Shortened PK fork, drilling for the rails and a lot more things to do...
Positive
Ginch wrote: That's a PX drum on there?
Positive
SaFiS wrote: Yes. We don't like the PK drum. They're interchangeable… |
Ginch wrote: Is the offset the same? I'll try a PK drum on a PX when I get the time… |
SaFiS wrote: Yes. We don't like the PK drum. They're interchangeable… Or there's another version? |
SaFiS wrote: I think they're the same but since the leg gets also rotated before welding it doesn't really matter… I was thinking that because the PK drum is made for 3" wheels and the PX for 3.5", they might have a different offset built in. Just guessing though! 108 wrote: Doesn't it look similar? Honestly question… Or there's another version? ![]() |
Ginch wrote: Rotated? I don't follow, how does that work? You don't put it back together in the same alignment? I thought that was what the mark across the cut was for. I was thinking that because the PK drum is made for 3" wheels and the PX for 3.5", they might have a different offset built in. Just guessing though! The PK drum is a lot "squarer" isn't it? I'm not sure this is representative of all PK's but I'm not very familiar with these. ![]() Don't think it's too much, 1mm to 3mm depending if it stays drum or goes disc… As for the drums, yes the PK is squarish and looks weird on a V range. Repros for PKs are same as PX nowadays. Offset wise they're probably the same, I'll have to check them though… ![]()
Positive
SaFiS wrote: I mark them for reference, then I twist the bottom where it needs so the wheel ends up dead center to the track of the frame. If you just put a PK fork in a V frame the wheel is offset… Don't think it's too much, 1mm to 3mm depending if it stays drum or goes disc… As I said, I haven't tried it myself but this is how it seems to me. The thing you did earlier changing the length of the axle was how I imagined it would work... although I'm probably getting the fork mixed up, that might have been an auto fork? |
Ginch wrote: The PK drum is a lot "squarer" isn't it? I'm not sure this is representative of all PK's but I'm not very familiar with these. |
Ginch wrote: I kind of feel like that wouldn't work to change the offset? Obviously you have much more experience in this area than I do. But I can imagine that the dominant force when the scooter is in motion is that the centreline through the trailing arm is going to dictate the direction of travel, no matter what. IE, the tracking is not changed. Meaning (I think?) that the top part of the fork would be turned 1 to 3mm, and this would be made up for at the headset and pinchbolt? As I said, I haven't tried it myself but this is how it seems to me. The thing you did earlier changing the length of the axle was how I imagined it would work... although I'm probably getting the fork mixed up, that might have been an auto fork?
Positive
SaFiS wrote: I mark them for reference, then I twist the bottom where it needs so the wheel ends up dead center to the track of the frame. If you just put a PK fork in a V frame the wheel is offset… Don't think it's too much, 1mm to 3mm |
108 wrote: Forgot to ask, is this fork shortened?
Positive
Always thought the pk conversion was to address a tilt in the wheel and not everyone shortened the fork.
Good to know, as im thinking I might do this in the future. |
![]() UTC
Innovator
Innovator
Nice!
I can't even fit the engine door on my Smallie. The Quattrini cases and cylinder are too wide. Naturally, it never bothered me until I tried and realized I couldn't do it. |
chandlerman wrote: Nice! I can't even fit the engine door on my Smallie. The Quattrini cases and cylinder are too wide. Naturally, it never bothered me until I tried and realized I couldn't do it. Is it just the case the whole flywheel side is wider? The crankcase clutch side should be the same as stock right? |
![]() UTC
Innovator
Innovator
108 wrote: Which part of it that hits the door? Is it just the case the whole flywheel side is wider? The crankcase clutch side should be the same as stock right? If I ever paint it, I'm going to cut and widen the cowl so it'll all fit, I think. |
Yeah, Quattrini cases are bigger. There's a wider carbon door for them made by Tomas Compositi or you can make your own...
https://www.sip-scootershop.com/en/product/side-panel-door-tomas-compositi-racing-cylinder-m200_5095M200 Almost there with the smallie. Tried the flywheel cover to check for clearance with the engine door, drilled for the regulator, carriage hook and a main switch for extra safety. I only need to finish with the fork and the mudguard... ![]() ![]() ![]() ![]() ![]() ![]() Preserved original importer sticker from 1978... ![]()
Positive
