Firstly if you get a timing light hooked up to the older 6 Volt Vespa system, was it bright enough and funtional? Where did you connect the alligator clips to get 6 Volt DC?
![]() 73 & 74 Rally, 76 ET3, 80 P200, 61 Ser 2, 65 Silver Special,, 2015 HD Road Glide Special
Posts: 5259 Location: Oceanside, CA |
Dont know how youre going to get 6V DC unless you have a 6V battery. What model scoot are we talking about?
Also dont know of any timing lights that are 6V. Maybe something from the 50's/ 60's? Everything else I've seen has been 12V DC. |
I'm running a 1968 Sprint. AC comes off the stator and goes to rectifier? Headlamp bulbs use DC right! Wouldn't 6volts just make it half as bright if you had a 12volt timing light?
![]() UTC
Lucky
Posts: 10886 Location: Nashville 284 Days Since Last Explosion |
Lucky
![]() 76 Sprint V, 63 GL, 62 VBB, 05 Stella, 66 Smallstate, 66 Lammy S3
Timing lights want 12V DC. They might work with 6V DC, but I don't think they work at all of AC, regardless of voltage.
Johnny Two Tone
![]() '15 GTS300, '86 PX125EFL, '66 VBB, '01 ET4
Posts: 9004 Location: San Diego, CA |
Power the timing light with your car battery. It just wants 12v, doesn't care where it comes from.
Positive
![]() 1964 Allstate Cruisaire, 2022 Husqvarna Vitpilen 401, 1972 Suzuki T500J
Posts: 1082 Location: York, PA (the intellectual center of the universe) |
Static or Dynamic? If you just want to static time, this works well. And with the LED there is no "did the bulb just get brighter?", it's on or off, which is nice.
Static timing light |
bodgemaster
![]() 63 GL, 76 Super (x2), 74 Primavera (x2), 79 P200, 06 Fly 150
Posts: 7223 Location: So Cal |
Most timing lights need a 12v DC battery to power the strobe. The draw is very small.
I keep one of these around. A battery charger works too. ![]() |
Found a $20 timing light. And a 12 volt kids atv battery, wonder if it will work.
https://www.facebook.com/marketplace/item/1571250473404030/ |
My sears timing light looks a lot like that one and works. You might be able to search up the model number to see if you can find the manual or any info on it.
![]() '64 Motovespa 150S (177) , '65 VBB, '66 Allstate SF, '66 180SS, '58 LD 125 (150)
Posts: 2077 Location: S.Salem, NY |
I have one of these and it works perfectly on scooters and cars:
https://www.amazon.com/Performance-Tool-W80578-Self-Powered-Timing/dp/B002KS72GA/ref=asc_df_B002KS72GA/?tag=hyprod-20&linkCode=df0&hvadid=312695966306&hvpos=&hvnetw=g&hvrand=11591082167315897703&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9004187&hvtargid=pla-434343701173&psc=1
Positive
