So I've looked around, for hours.. And I did find people with similar problems, but it always ends up being a clamp that's not tightened, or nothing gets fixed because apparently it just self healed.
But I have a leak coming from the housing of the waterpump. It's not the "funny-shaped" gasket on the waterpump cover where the hoses connect. It's from the dark depth behind :')
And someone mentioned a weep hole? And that it's there for the tiny amount of coolant that can get through to the wrong side.
But there's not a tiny amount in this case, and it's dripping also when cool and not running.
This "gasket cog" (nr10), could that be the problem? Because I'm guessing that the bearings (nr9) are not stopping any fluids from leaking through. And also, I guess there is just air and not oil on that side, because if there was, it would just pour out of the weep hole?
I've been searching like mad man, but can't find any hose or gasket above that could be the source.
