1963 VBB, 1974 90
1963 VBB, 1974 90
Picked a sweet 1974 90 earlier this summer that had a number of electrical issues. The prior owner installed a 12v battery by mistake and all the bulbs were blown as well as the flasher relay. Any recommendations for the headlight/mounting clamps? After searching I can't find anything close to the amazingly over built bulb assembly that is in there.
I'm also looking for a bit more power but also something that's bolt-on with no frame modifications required. I've already installed a SHBC 19.19 and banana which helped.
I was looking at these from SIP. Any recommendations from y'all experts?
Racing Cylinder SIP PERFORMANCE 125 cc 6 Travasi
Racing Cylinder POLINI Mono 130 cc
Racing Cylinder POLINI Racing 130 cc
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
get the euro bulb conversion for the headlight. it's an easy swap.
@roland87 avatar
@roland87 avatar
I vote for SIP cylinder. It is the same as VMC GS 125cc. Only seems with modified cylinder base so you don't need to cut flywheel dust cap to mount cylinder.
I have it on my 50 Special and very happy with it. Here you can find more details of my setup.
1963 VBB, 1974 90
1963 VBB, 1974 90
I'm not sure what euro bulb conversion is, sdjohn. Do you have a link?
@mjrally avatar
@mjrally avatar
Euro style only the bulb inside the lens needs to be changed. American style, the whole shebang is a sealed beam and everything needs to be changed.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
@oopsclunkthud avatar
1:3
sdjohn wrote:
https://www.scooterwest.com/vespa-small-frame-headlight-euro-type-115mm-143075.html
that one does not have the ears like the US headset.
here's the one you need:
https://www.scooterwest.com/usa-head-light-for-vespa-rally-sprint-super-small-frame-114345.html
@greasy125 avatar
@greasy125 avatar
are you going to leave this 3spd?
if so, then the name of the game is torque. you've already got the 19 and banana, so that's bueno.
I'd lean toward one of the flavors of the polini 130 (standard or the mono), or if you wanted to be super budget an Olympia or DR would be fine. the VMC stuff is super nice, but they all but practically require porting the transfers to match. where as the polini you can just snap on and go, or just gasket match if you're feeling frisky.
either way you're going to need new cylinder studs and cylinder shroud.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
Oops has it right, I linked the wrong one for you
1963 VBB, 1974 90
1963 VBB, 1974 90
Thanks oopsclunkthud and sdjohn. That's exactly what I need
greasy, yeah for the season --- or a few seasons --- I'll likely stay 3spd. City riding within a couple miles the 3 is still fun.
Thanks all.
@ccsp03 avatar
Rally 180, TS 125, PX 150 and a lot of smallies
@ccsp03 avatar
@ccsp03 avatar
@ccsp03 avatar
[ Time: 0.0139s ][ Queries: 4 (0.0038s) ][ live ][ 343 ][ ThingOne ]
