I am having a nightmare of a time with fuel starvation on this scoot. I have taken the fuel tap apart, have changed out the fuel lines and installed a filter, rebuilt the carb a half dozen times, and I have confirmed the fuel cap vent works. I have had times when it runs great and I can ride around the block and then I will end up in a situation where i'll have to kick it 30 times, and then it will rip to life, run for 20 seconds and then die again.
The only idea I have is that I shouldn't be using the spring loaded float needle but that doesn't completely make sense to me unless my fuel consumption is high enough that fuel flow won't keep up.
Is it possible that the early VBA fuel tap is just not free flowing enough? That doesn't really explain why it does/doesn't run sometimes. I'm mildly concerned that the way that the fuel tap exits the tank (straight down) that i'm kinking the fuel line and restricting the flow.
Thoughts? I'm at wits end.
H
