@germangtsdriver avatar
Vespa GTS 300
Vespa GTS 300
For the Vespa GTS is finally also a rear hight reducer kit available. For the Vespa Primavera / Sprint there is already a little longer.
For the Vespa GTS, the height reducer kit should bring about 2cm reduction (0,78 inch) in seat height, so that rider comes better with the feet on the ground.
Attention: only in compatible with series shock absorbers and series exhaust.
Vespa GTS rear hight reducer kit:
https://www.sip-scootershop.com/en/product/height-reducer-kit-rear_MV3025003
Vespa Primavera/Sprint (only 125/150):
https://www.sip-scootershop.com/en/product/height-reducer-kit-sip-rear_MV667872
(one of multiple available products)
That price though
Vespa GTS 300
Vespa GTS 300
znomit wrote:
That price though
I paid 600€ a few months ago for a modified seat (including matching Topcase backrest) so that my daughter could better get her feet on the ground after she has flipped over the Vespa when she pushed the Vespa backwards while she was sitting on it (2000€ damage).
If I could have escaped with 150€, it would have been a bargain ...
Seriously, a large part of the price will be due to the certifications (ABE) required in Europe (and especially Germany), otherwise it would not be allowed to be used on the roads here.
@mike_holland avatar
GTS300 Super 2023 Beige
Don't forget to adjust the headlight after installing this.
stumbled across this solution to gain another bit
https://www.aliexpress.com/item/1005005809816123.html
@anndee4444 avatar
GTS 250
@anndee4444 avatar
GTS 250
Here's what no rear shocks looks like. The motor ends up touching the gas tank, and exhaust hits the side, and I'm pretty sure the pet carrier wouldn't fit either.
no rear shocks
no rear shocks
@anndee4444 avatar
GTS 250
@anndee4444 avatar
GTS 250
GermanGTSDriver wrote:
I don't like how this part isn't keyed to stay straight. If it got loose it would rotate.
https://images.sip-scootershop.com/cdn-cgi/imagedelivery/7WkrUYN4GAew8Bx4sug9hQ/P0BpqD099k68SgyY10PVYQ/600x600
@californiacruising avatar
2015 Sprint 150, 2018 GTS 300
and good ole Robot with a tutorial
[ Time: 0.0094s ][ Queries: 4 (0.0032s) ][ live ][ 343 ][ ThingOne ]
