Hi in our workshop we have a 2012 Piaggio X10 the ABS light is on all the time and ASR light is flashing.
So far we have checked the tyre pressures which are okay, then the battery was showing weak so we replaced that and went for a test ride and the fault is still there where should we try next ?
Many Thanks Ben
@louswheel avatar
150 Sprint Veloce, RE Meteor 350
@louswheel avatar
From the time I had a X10, check the sensors on the front and rear wheel, and check that the sensor ring on both wheels are true. I found that my rear sensor wheel was slightly buckled, and the ABS light on the dash kept on.. BTW, they are fine scooters, miss mine!
Graham
[ Time: 0.0233s ][ Queries: 3 (0.0093s) ][ live ][ 343 ][ ThingOne ]
