@abner_bjorn avatar
@abner_bjorn avatar
Check it out MV. I picked up a BV250 a while back. I love the bike, but can't stand the seat. After a 20 minute ride in 85 degree temps, I described the experience as wearing a pair of vinyl Speedos that are 2 sizes too small. Something has to be done. I'll post pics along the way. First step getting rid of that awful hump. With the dome gone, I had 4 solid mounting points on the same plane, top and bottom. I sandwiched 1/8" sheet aluminum on each side securing with epoxy and pop rivets. 8/22, I have the foam work done, and the seat shape is where I want it. I removed over 1.5" at the horn, and carved the rider depression back over an inch. It's looking an awful lot like my Granturismo seat. 8/23, I took it out for a 40 mile ride this morning. I don't like the interaction between the different pieces of foam and my tailbone. I've ordered a silicone gel pad to address this.
Piaggio, form over function every time.
Vinyl and foam removed.
Take a deep breath and start to cut.
Top of seat pan.
Top of seat pan.
Bottom of seat pan.
Bottom of seat pan.
8/22  Re-shaped seat.
I should have planned on this from the start.
@abner_bjorn avatar
@abner_bjorn avatar
If it's good enough for Dolly, it's good enough for me. I have inserted the silicone gel pad, and covered the whole seat with 1/8" dense foam. It's ready for upholstery.
Gel pad in place.
Gel pad in place.
@abner_bjorn avatar
@abner_bjorn avatar
I finished up my seat today. My wife cut the center skin out of the original upholstery and sewed a piece of marine vinyl in it's place. I stretched it in place and stapled it home.
Stella
Stella
What did you use to cut and shape the foam?
I've been toying with doing the same to a scoot my wife has..
@abner_bjorn avatar
@abner_bjorn avatar
Sorry for the late reply. I used a long skinny bread knife to do the big work. Next was a 4" angle grinder set up with an 80 grit sanding disk. I also used a couple of different rasps and a sanding block with coarse sandpaper. I've put about 1,500 miles on the scooter since I finished the seat. I am very pleased with how it turned out.
I added a $6 Aliexpress mesh seat cover. My work here is done.
[ Time: 0.0131s ][ Queries: 4 (0.0068s) ][ live ][ 343 ][ ThingOne ]
