I have noticed on my 2023 GTS Supertech 300 when the rear brake lever is pulled that the engine loads up under a strain and there is a slight vibration. Anyone have any idea why?
mine does it too. i just assumed it's a power-assist off vacuum or something that causes just a tidge of extra load at idle.
hasn't caused any issues (at least not yet), so i can't imagine it's a major thing. |
Do you mean that when you pull one/both brake levers while stationary, the noise changes and slight vibrations may occur?
Then this is absolutely normal. Pulling the brake creates a frictional connection, the noise changes and vibrations from the engine can be transmitted (differently) to the body via the brake, brake caliper, chassis, etc. When the brake is released or applied, the path of transmission of the vibrations changes / the "oscillating" mass changes.
Positive
GermanGTSDriver wrote: Do you mean that when you pull one/both brake levers while stationary, the noise changes and slight vibrations may occur? Then this is absolutely normal. Pulling the brake creates a frictional connection, the noise changes and vibrations from the engine can be transmitted (differently) to the body via the brake, brake caliper, chassis, etc. When the brake is released or applied, the path of transmission of the vibrations changes / the "oscillating" mass changes. However, I was never told why. Your answer is very interesting, I never thought of that. Thanks |
GTS300 Super 2023 Beige
Posts: 3501 Location: Sydney, Australia |
When the brake is applied, the pressure in the brake line forms a "solid" connection between the engine and body allowing the vibrations to get through, bypassing the suspension.
Positive
GermanGTSDriver wrote: Do you mean that when you pull one/both brake levers while stationary, the noise changes and slight vibrations may occur? Then this is absolutely normal. Pulling the brake creates a frictional connection, the noise changes and vibrations from the engine can be transmitted (differently) to the body via the brake, brake caliper, chassis, etc. When the brake is released or applied, the path of transmission of the vibrations changes / the "oscillating" mass changes. |
Mike Holland wrote: When the brake is applied, the pressure in the brake line forms a "solid" connection between the engine and body allowing the vibrations to get through, bypassing the suspension. |
Posts: 46114 Location: Pleasant Hill, CA |
MrTaz wrote: I never thought of that as a possibility. Very interesting and a likely reason. |
Grumpy Biker
Posts: 5742 Location: Sparks, Nevada, USA |
