mp3 250ie 2007
mp3 250ie 2007
Hi all i recently bought a Piaggio p3 250 ie 2007
the bike was fine to ride but was sluggish so i fitted a new spark plug and fired the bike up it started just fine so i then turned the bike off now i cant start the bike i notice the front light are off also after checking all fuses and the battery is at 13v. it just will not start when i turn the bike on i hear the fuel pump prime and i hear the starter motor trying to start but nothing. i also took the plug out and then started the bike i can see petrol coming out the spark plug hole.
i took the front fairing off the bike and checked all the 80amp fuses and cleaned them. still no go i really don't know what else to do any help would be great guys.
@jkj-fz6 avatar
BV400, Primavera 150
@jkj-fz6 avatar
Because you changed the spark plug just before it wouldn't start — I'd first suspect the spark plug wire. Is the cap seated all the way on, and tight? Did you pull the wire out of the cap when you pulled it off?
mp3 250ie 2007
mp3 250ie 2007
Hello mate so the bike was working fine but sluggish and i could tell the spark plug needed a new one. so i took the old one out fitted a new ngk plug fired the bike up it started just fine i left it then turned the bike off 5mins later i went to fire the bike up but it cant fire up the pump i hear fine the started i hear trying to start everything seems ok it just does not fire i will post a video
ps i tested both spark plugs and i can see a good spark from both.
@jkj-fz6 avatar
@jkj-fz6 avatar
I would still look for a bad connection in the spark plug wire. It possibly was good the first time when the scooter started, but vibrations loosened the connection. The unburned petrol is another clue. Check for spark.
2009 mp3
2009 mp3
Had the same problem with the injector dumping fuel in as soon as the ignition was on and found that fuse 11 I think was high resistance but the fan ran all the time as well. Check that you have batt voltage both sides of fuses 7 to 12 they look OK but are prone to giving trouble
mp3 250ie 2007
mp3 250ie 2007
Hi guys i tried everything still no go new battery plus new spark plugs i have ordered a new spark plug coil unit not sure how to get to the other one under the seat i am fed up with it now anyone want a free motorbike.
mp3 250ie 2007
mp3 250ie 2007
JKJ-FZ6
just a quick question you say did i pull the wire out of the cap ? which wire
the ngk plug is tight on the coil
mp3 250ie 2007
mp3 250ie 2007
after fitting a new solenoid and spark plug cable it fired up but.....
the recommended spark plugs when fitted the bike fires up and stalls. so i used a spark plug with a thin top section and it worked just fine Piaggio really need to sort out their spark plug connectors its not a tight fit at all i had to cable tie the ngk spark plug tip to a cable to make sure it does not fall out.
mp3 250ie 2007
mp3 250ie 2007
hi guys if you are interested i found the issue and its an odd one
i found the owner before be fitted an alarms system and 3x speakers 1 for the indicators to beep 2 for an audio voice when the alarm is on and 3 i don't know the 3rd one and i can see wiring for heated grips i have take all this out and i can confirm the battery is how holding charge at 13v and its stable. thank you for all the help.
[ Time: 0.0082s ][ Queries: 3 (0.0017s) ][ live ][ 343 ][ ThingOne ]
