Anyone have tricks for fixing a vent steering stop without messing up the horncast? Without dropping the fork? Any secret tools?
Was thinking maybe needle nose vice grips would work.
Posts: 15118 Location: The state of insanity, SoCal |
depending on how it's bent you *might* be able to get in there with a long rod or punch and give it a good whack to reposition it.
you already know this, but dropping the fork is the best way to tackle it. |
The Dude
Posts: 2450 Location: PNW from LBC |
Greasy offers good advice. Large punch or something your can smack with a big ole hammer. Tough to do that with the angle of the horncast / steering stops...
Another option is the Voodoo technique. Voodoo is your man here! He has a good technique, that I believe others have used with good success. Let me see if I remember, and I'm sure others and hopefully the man himself Voodoo: Drop that fork Get a very large socket, or equivelant heavy duty thick wall pipe Cut a groove into it with a grinder. make the groove just thick enough to slip over the metal on the steering stop area. Get yourself a big breaker bar, or something strong to fit into the socket/pipe. Use that bar as a handle in the socket/pipe, to bendy the steering stop back into place. Feel free to smack it with a hammer. The idea is to make small adjustments to 'massage' the thick steel back into place. Some heat from a small torch is probably your friend. Mind the paint. I'm sure I did a beyond sub-par job of explaining this process... but hopefully this will start you on the path.
Positive
Posts: 2563 Location: Siam |
There is a guy here who uses Voodoo successfully to cure this ailment.
I just read the above, so he now has two recommendations. |
bodgemaster
Posts: 7640 Location: So Cal |
GeekLion described the technique. Fork has to come out.
Here's some pics:
Before
The Tool
Massaged
Positive
Alright guess I'm dropping the fork! Sometimes you have to do things the right way.. Now I gotta go cut up a socket -thanks for the replies and the photos y'all.
Positive
bodgemaster
Grumpnut wrote: You can accomplish the same with a crescent wrench |
i've done it two ways:
heat it up with oxy-acytelene and bend it back into place. TIG weld it up. |
2007 Stella 225
Posts: 3547 Location: Rochester, Minnesota |
I'd be tempted to try and make something like this. Right and left half, so you could fit it through hole, then figure out a way to attach back together.
