@scrumpadelic avatar
73 Sprint w/ P210
73 Sprint w/ P210
So I gave my clutch basket to a neighbour to weld a band onto it and the holes I'd drilled in between the rivets (from Freak Moped's tutorial on strengthening a clutch for a tuned engine) and the knobhead left it outside and it got rained on. There's some rust on the welds now
I sprayed the shit out of it with wd-40 right away now asking what I should do with the thing; paint it? Smear it with grease? Leave it alone and stfu?
@mjrally avatar
@mjrally avatar
I wouldn't paint it as any paint that flakes off is going to get in your gears/seals. I'd get a wire wheel and hit the rust and install. The oil bath will keep it preserved.
73 Sprint w/ P210
73 Sprint w/ P210
MJRally wrote:
... any paint that flakes off is going to get in your gears/seals.
Oh so you've seen my paintwork Razz emoticon
Good advice. I'll wire wheel the rust that's there - it's just a bit of surface rust, clean it and sit it in some gear oil until I reinstall the clutch.
Big thanks.
@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
You could soak it in a bowl of white vinegar, since your not in a hurry give it a day or two.
73 Sprint w/ P210
73 Sprint w/ P210
Good call- thanks for the input. I used the wire wheel last night and it came off easy peasy.
[ Time: 0.1588s ][ Queries: 3 (0.1011s) ][ live ][ 318 ][ ThingOne ]
