Vespa gts 300
Vespa gts 300
Hello anyone have issue with the rear lightnot sitting flush to the panel. Its so annoying any help be much appreciated.
Regards
Not flush 😪😪
Not flush 😪😪
@halijaro avatar
@halijaro avatar
Welcome to the forum.
It's within warranty, so why not query it with the supplier? If it's not how it should be they would be obliged to put it right.
@25bikez avatar
2009 Genuine Stella 2T (Sold). Helix Hunting.
@25bikez avatar
Laminar flow capture. Makes the bike loads faster...
Gts hpe supertech
Gts hpe supertech
Could try adjusting it. Might just not be seated correctly. Not sure how the new ones mount, but my '22 is one screw and two tabs you push in.
@jeffsvisor avatar
2023 and 2024 Vespa GTS300 SuperTech
@jeffsvisor avatar
I have a 2023 GTS300 SuperTech and just checked my light and it was flush and tight to the body.
@mike_holland avatar
GTS300 Super 2023 Beige
Undo the 10mm nut behind the taillight and it will pull off. There is a three wire plug there, and chances are it is not attached to the black plastic bracket below it, so that the headlight is rocking on the plug. I just found this out the hard way today, after changing my variator rollers.
@bluejeep avatar
2023 Vespa GTS
@bluejeep avatar
2023 Vespa GTS
Hi scotty,this is my 2023 gts,seems the outside edge doesn't fit as well as the middle section on mine.
@shaardvark avatar
2023 GTS300 Super
@shaardvark avatar
2023 GTS300 Super
I had the same issue after I added a Brake Light Flasher. The fix was to add a rack and a top case so I can't see the problem. True story.
[ Time: 0.0111s ][ Queries: 4 (0.0046s) ][ live ][ 343 ][ ThingOne ]
