@rocklanddad avatar
2022 VESPA GTS 300
@rocklanddad avatar
2022 VESPA GTS 300
If you read my previous post from Wednesday about my scooter failing etc etc - spent the last 24 hours at the dealer. I was assured that they looked over everything and everything is perfect. About 25 miles into my 50 mile ride home. The same exact thing happened again. Exactly the same.
I was going, then all of a sudden very slow…..stalled. Wont start they told me to wait till it cools down again that should start up and then go put gas in it which I have done.
I guess my question for all of you here is now that he thinks it's the fuel pump. Why does this have to happen again for it to be figured out?
They are a great shop, but I'm starting to get frustrated obviously
@bluside avatar
2020 GTS 300, 2011 LX150ie
@bluside avatar
I can't give any advise but I feel your pain. I would be very upset also. Enough already.
They have a good coffee machine and nice couches for you to sit on while they stare at your scooter with a confused look on their faces?
@jkj-fz6 avatar
@jkj-fz6 avatar
Thoughts on fuel pump: Was it a hot day? Temperature?
Was the fuel tank near empty?
I had fuel pump problems with my Yamaha scooter on very hot days, until I replaced it. Also, fuel in the tank has a cooling effect on the pump, so don't let the fuel level get too low on hot days.
@mjrally avatar
@mjrally avatar
When you turn the key on, do you hear the fuel pump whine to prime the system? Or no?
If yes, I know it's not a direct comparison, but on vintage scoots when the CDI is dying, it can show its dying by losing spark when hot. Magically you'll find spark once the CDI has cooled down. Happened to me after the tow truck had brought me home. I had to replace the CDI entirely. No way to repair.
nope
@rocklanddad avatar
2022 VESPA GTS 300
@rocklanddad avatar
2022 VESPA GTS 300
On Wednesday when it happened it was a hot day yes. Today, not so hot.
I had two lines left on the tank so low fuel light wasn't on yet - but I filled it up after it started up again
I have 7100 miles on the bike. At 500 miles the factory installed fuel pump went and they gave me a new one back then.
@rocklanddad avatar
2022 VESPA GTS 300
@rocklanddad avatar
2022 VESPA GTS 300
Yes, when I turned it on, I hear the fuel pump. I remember when my first fuel pump went at 500 miles when I turned the ignition on I didn't hear anything. Of course now I think when I turned it on the WHIR is not as loud…..but maybe I am looking into it
nope
2019 GTS 300 HPE w Malossi
have the valves been adjusted?
Cracked injector?
@greasy125 avatar
@greasy125 avatar
ohh! sounds like something electrical which is always super fun!
something is getting hot and quitting. pump, injector, stator, ECU...
I wouldn't rule out an HT coil, lead or cap either.
this always sucks because it's soooo difficult to track down.
@kz1000st avatar
@kz1000st avatar
I would do something a little off the wall. Dump some Seafoam in the tank. Maybe ethanol crud is clogging up the works.
If anything, ethanol helps clean up the works. Seafoam is for 2 stroke marine engines. No, there is some electrical gremlins fooling about. I am sorry about this nonsense, RD. I think you should try another shop.
@rocklanddad avatar
2022 VESPA GTS 300
@rocklanddad avatar
2022 VESPA GTS 300
My thought process is I'm going to give the shop one more try. What I like about it is its Vespa only. The other relatively local dealer sells everything and also Vespa's.
@nautiker avatar
'14 Piaggio BV 350
@nautiker avatar
'14 Piaggio BV 350
I'm starting to think ECU or fuel pump...
Sorry this happening to you, I know I get upset when one of my vehicles isn't reliable...
@rocklanddad avatar
2022 VESPA GTS 300
@rocklanddad avatar
2022 VESPA GTS 300
The same thing happened on Wednesday. They replaced the ECU yesterday……..and the fuel pump was replaced at 600 miles, but today on the phone when I was pretty much stranded - the guy at the dealer thinks that is what's happening AGAIN!!!!!!! So pissed. And I noticed a little scuff mark on the side of my bike that def. wasn't there when the tow guy picked it up. I know I am being a baby, I am just not happy right now. After it cooled down I filled up the tank (had two bars left so it wasn't empty, was planning on getting gas anyway before this happened) and rode 25 miles back home and it was fine, but my question still remains……
If it's the fuel pump, why wasn't this picked up yesterday when they went over everything on the bike?? When I picked it up they said they went over everything in detail. If that's the case, why want this picked up?? Thoughts?
Looking into buying a Yamaha, Honda or BMW scooter if this keeps up.
@nomad68 avatar
Honda GB350S - not a scooter
@nomad68 avatar
Japanese is the way to go
@bill_dog avatar
eeeee bip
eeeee bip
@bill_dog avatar
I agree with Nomad.
Sell it and buy a Burgman.
I promise you you'll have nothing to complain about.
The Burgman 400 being a maxi-scooter, won't be as flickable, but is a really nice ride. And better than it's brother the 650 - which is true highway scoot, but much heavier.
@rocklanddad avatar
2022 VESPA GTS 300
@rocklanddad avatar
2022 VESPA GTS 300
I have ridden a Burgman before…….I love my scoot for the nimbleness which I cruise around Manhattan's traffic. I am hopeful that the dealer is right and it's my fuel pump, the first which failed at 500 miles and the second to fail just 6500 later. Perhaps after the new install, we will be all set. Fingers crossed.
@nomad68 avatar
@nomad68 avatar
This ^^^
@rocklanddad avatar
2022 VESPA GTS 300
@rocklanddad avatar
2022 VESPA GTS 300
Nomad68 wrote:
This ^^^
Burgman feels big and bulky.
@kz1000st avatar
@kz1000st avatar
@bill_dog avatar
eeeee bip
eeeee bip
@bill_dog avatar
I'll have that thank you very much.
@coddy avatar
@coddy avatar
Just for the record friend of mine has just broken down on two consecutive Scooter Rallies and had to use a Breakdown service to get home both times missing the Rallies completely.
His scooter? Suzuki Burgman 400
Is he using the same dealer as RocklandDad for service?
@phaskins avatar
2006 250ie
Location: Bellingham, WA (when Im not out on a trail somewhere)
@phaskins avatar
2006 250ie
ROFL emoticon
@rocklanddad avatar
2022 VESPA GTS 300
@rocklanddad avatar
2022 VESPA GTS 300
I rode all day doing little jaunts around town - and then when I got home I let it idle for 45 minutes - fan came on and off a bunch ……. Is there a chance that something like this can correct itself?
If it's electrical connector related then sitting still might not cause the fault.
@rocklanddad avatar
2022 VESPA GTS 300
@rocklanddad avatar
2022 VESPA GTS 300
I didn't sit still……prob put 30 miles (3 different errands) in today. Of course I was uneasy.
Does he maintain it? Anything will brake down eventually if not taken car of.
@bill_dog avatar
eeeee bip
eeeee bip
@bill_dog avatar
He went to a scooter rally on a Burgman in the UK ?
That was his first mistake.
Mine did a 10 day ride from LA to New Jersey via Wichita much of it in 95 degrees with 52,000 already on the clock.
All good.
@adri avatar
Atypical Canadian
Atypical Canadian
@adri avatar
skids wrote:
I would look into lemon laws in the state of New York where you live.
You beat me to it.
OP has been more than patient and reasonable. Time to start kindling a fire under their asses.
@adri avatar
Atypical Canadian
Atypical Canadian
@adri avatar
Friends don't let friends buy Burgmans.
The fact you have one confirms my suspicions about you
@bill_dog avatar
eeeee bip
eeeee bip
@bill_dog avatar
I have an enabler. I also pay people to make me look good.
Rock, Picture someone who has a very attractive partner who no matter how much they promise to remain faithful they can't stop sleeping around.
It's about trust. When the trust is gone it's time to leave.
@rocklanddad avatar
2022 VESPA GTS 300
@rocklanddad avatar
2022 VESPA GTS 300
If they replace the fuel pump and I have no issues, we're good. I'm giving them one more shot.
When I rode a friends Bergman last year, it reminded me of how much I love my scooter.
Yes, I have been patient and kind. It's my nature - one more shot that's it
@bill_dog avatar
eeeee bip
eeeee bip
@bill_dog avatar
Burgman with a U.
It's German for Hill.
@rocklanddad avatar
2022 VESPA GTS 300
@rocklanddad avatar
2022 VESPA GTS 300
Bill Dog wrote:
Burgman with a U.
Apologies for the misspelling…… I was using the voice thing.
I understand why you love it……
@bill_dog avatar
eeeee bip
eeeee bip
@bill_dog avatar
Which is why my next new motorcycle will probably be a Honda.
Boring, soulless, reliable.
[ Time: 0.0137s ][ Queries: 3 (0.0049s) ][ live ][ 343 ][ ThingOne ]
