Hello,
I have a P200E on which I had installed a SIP Speedo V2 with digital speed sensor that uses the speed cog from the front hub.
Does anybody have a SIP Speedometer V2 power box at hand? I try to find out what is the expected voltage output for red and blue wires. Black is ground and brown are related to RPM I guess.
The blue wire at my box got pinched and cut. I soldered the wire together but I want to confirm if my box is ok.
The result of this accident is that my speedo stopped measuring speed. I try to make sure that power box is working correctly.
