@mitleider avatar
2024 GTV & 2024 GTS Supertech
@mitleider avatar
Ragazzi.....look carefully at the picture attached excerpted from the fabled Rizoma website. It shows a black Rizoma-branded exhaust ..! Never saw this before.
Does anyone know details, I.e. part number or cost or where to find more information?
Grazie
@sadragna avatar
GTS SUPER 300
@sadragna avatar
GTS SUPER 300
I was looking to do an exhaust on my Vespa and when I took in for first service I was talking to the tech and service manager and they being seeing quite a few scoots coming in with check engine lights on after adding the slip on exhaust. Also it was from different manufacturers as well.
@yellow300gts avatar
300 GTS supertech HPE
as i have learnt, is that a slip-on makes the engine run lean, therfore you need the Malossi Force master to feed the engine more fuel.
No lamps lighting with me
I use a malossi o2 lambda emulator to hopefully give it a bit more fuel (it's cheaper than a force master and doesn't take skill to correctly adjust)
[ Time: 0.0091s ][ Queries: 4 (0.0022s) ][ live ][ 339 ][ ThingOne ]
