Mon, 04 Sep 2023 15:16:23 +0000
PX125
PX125
Mon, 04 Sep 2023 15:16:23 +0000 quote
Hi guy's, I am new to the forum, I have a bgm177 kit and have just split the cases of my px125 ready to get the ports matched. I have read about removing the gates on the barrel and widening the ports on the barrel then matching the cases.
Does anyone have experience of doing this?
Can pictures be posted if possible?
I would prefer not to have to weld the cases, can this be avoided?
Many thanks for reading and any responses 😁
Mon, 04 Sep 2023 15:26:20 +0000
Lucky
76 Sprint V, 63 GL, 62 VBB, 05 Stella, 66 Smallstate, 08 Stella (for now)
Lucky
Mon, 04 Sep 2023 15:26:20 +0000 quote
I've done it several times. I even made a video the last time I did it.
Mon, 04 Sep 2023 15:39:08 +0000
PX 200
PX 200
Mon, 04 Sep 2023 15:39:08 +0000 quote
If you weld the cases, try find someone good.
Potential failure points:
-Porous welding (crankcase leaks)
-Warping the cases
Someone who might have welded engine parts.
If not, I see a lot of European folk use this Weicon epoxy putty on Vespas.
Mon, 04 Sep 2023 15:44:04 +0000
PX125
PX125
Mon, 04 Sep 2023 15:44:04 +0000 quote
Thanks guys, I plan to avoid welding if I can, but I don't have a pre ported template to work from as in chandlermans video (which is helpful)
Thu, 07 Sep 2023 12:07:13 +0000
Thu, 07 Sep 2023 12:07:13 +0000 quote
Keep grinding till you get bored, or go out to other side...
Start off with the biggest thing you can fit in there!
Remember to champher the edges
Make a few holes in the lightweight piston
Grind off all the bits that cause seizes
Fri, 08 Sep 2023 00:42:28 +0000
2007 Stella 225
2007 Stella 225
Fri, 08 Sep 2023 00:42:28 +0000 quote
Won't that cause a loose fit and piston slap?
Fri, 08 Sep 2023 02:26:21 +0000
Fri, 08 Sep 2023 02:26:21 +0000 quote
It's the Flinstone's racing kit.
Fri, 08 Sep 2023 16:45:30 +0000
Fri, 08 Sep 2023 16:45:30 +0000 quote
I was reading an article about running more vs less oil in 2 stroke engines. One of the findings noted was that an underlubricated piston that was run hot and thrashed yielded an increase in hp in subsequent tests. I know that some types of automotive pistons had a deep cross hatch pattern on the skirts, though not to the extend of the piston shown.
Sat, 09 Sep 2023 04:53:32 +0000
Sat, 09 Sep 2023 04:53:32 +0000 quote
Nope, rings and bottom of piston are pretty much intact to ensure there is minimal slap.
Ground off bits were wherever there were seize points on pistons.
Cross hatching on exhaust to dissipate heat (something I learnt many moons ago from a tuner
Sat, 09 Sep 2023 04:59:18 +0000
Sat, 09 Sep 2023 04:59:18 +0000 quote
I did however stuff up the head while putting "Singh Grooves" in it,as went too far into the squish area!
Groovy
Sat, 09 Sep 2023 05:09:05 +0000
Sat, 09 Sep 2023 05:09:05 +0000 quote
Head design I did some time back
Sat, 09 Sep 2023 16:58:42 +0000
PX
PX
Sat, 09 Sep 2023 16:58:42 +0000 quote
Chandlermann, I have a silly question for you. Do you have any idea how much more power removing the gates and matcing the cases makes?
Is it a dramatic improvement or slightly noticable?
Cheers Robbie
Mon, 11 Sep 2023 03:39:40 +0000
Lucky
Lucky
Mon, 11 Sep 2023 03:39:40 +0000 quote
Cheers Robbie
I've never done a "before and after" test, so I can't say for sure. I know that there was a difference between ported and unported on DR 177's. In the neighborhood of 3-4 HP for my Stella using GSFDyno, if I recall.
  DoubleGood Design
[ Time: 0.0321s ][ Queries: 6 (0.0098s) ][ Debug on ][ 286 ][ Thing Two ]
