@rickster333 avatar
2001 ET4 "Mona"
@rickster333 avatar
2001 ET4 "Mona"
I'm planning a ride of about 60 miles tomorrow. It's going to be mid nineties.
When is it too hot for an air cooled engine? I have had zero problems so far this summer, but I do worry about the heat. I don't want to damage anything, and I don't want to walk home.
Would it be wise to remove the pet carrier for better circulation, or would it make things worse?
I'm interested in your responses. Thanks.
@jkj-fz6 avatar
@jkj-fz6 avatar
I think it depends on whether you can keep moving, or get stuck in slow traffic. I've had trouble on hot days. A new fuel pump fixed it with one scooter, a valve adjustment helped the other. For a sixty mile ride in 90 degree weather, I'd take the air conditioned car!
@mjrally avatar
@mjrally avatar
I'd say you'll be fine. I've ridden 110+ on both carbureted 2 and 4 strokes and I made it. The high oil temps worried me more than anything as the scoots wernt happy at idle.
Coming back, I just broke the trip up into little sections as it made me hydrate more and gave the scoots a chance to cool down.
@rickster333 avatar
2001 ET4 "Mona"
@rickster333 avatar
2001 ET4 "Mona"
Lol! That's funny. Oddly enough, I'm one of the crazies that likes hot weather.
Vespa GTS 300
Vespa GTS 300
In the region around Pontedera (Tuscany), the temperature regularly exceeds more than 40 degrees Celsius (=104 degrees Fahrenheit) in the summer...
@jimjar avatar
2012 LX150ie
@jimjar avatar
2012 LX150ie
I'm sure there is a practical limit, but I think we humans will give up before our bikes will. Here in Texas I don't worry about it at 105F, people in Phoenix routinely ride at 110F-plus. We'll likely hear from somebody that's ridden in more extreme heat with no ill effects.
2019 GTS 300 HPE w Malossi cylinder kit etc
^^ this
@rickster333 avatar
2001 ET4 "Mona"
@rickster333 avatar
2001 ET4 "Mona"
Thank you, everyone! I appreciate your answers.
@vintage_red_matthew avatar
MV Santa
MV Santa
I remember seeing a film produced by Volkswagen, I'm guessing in the 50s or 60s when all of their cars were air cooled.
They gathered about a dozen water cooled cars of various makes and on a hot day set out from a mountain valley to a high mountain pass and the Volkswagens were the only ones that made it to the top without overheating.
@rickster333 avatar
2001 ET4 "Mona"
@rickster333 avatar
2001 ET4 "Mona"
So, I took my ride and it was glorious! Thanks for your answers and assuaging my fears.
Mona ran great. Today is my 2 year anniversary of owning her. The ride today included some of the best discoveries that I've made of the bayshore area over the past 2 years...but not all by any means. The colors were spectacular and I hadn't even dropped a tab of acid. <G>
The heat was never an issue as it's all rural and I kept moving. Great fun!
@californiacruising avatar
2015 Sprint 150, 2018 GTS 300
SteelBytes wrote:
^^ this
Urban legend has it that back in the day the California motor cops use to burn up their air cooled Kawasaki KZs when doing low speed parade or crowd control duties
These are forced air cooled with the fan running all the time. You don't need to be moving for cooling.
@caschnd1 avatar
Grumpy Biker
Grumpy Biker
@caschnd1 avatar
Same here. After living in Arizona for 36 years (only owned a PTWs for over 15 years), I've seen days as hot as 122F. I changed my oil religiously. Only once did I get really concerned. It was 117F and I got caught on the freeway with traffic barely moving and the nearest exit 3 miles away. I was on my 1949 Harley-Davidson and the value of the motor alone was over $10,000. After a short while I could feel the motor starting to tighten up. I reached down and enriched the mixture as much as I could without fouling the plugs. Then I started lane splitting (illegal in Arizona) and got myself out of that mess.
That was one extreme case in 36 years of hot summers. Other than that one time, I never worried much about stop and go commuting.
@vintagescooterdude avatar
2006 GT200 2009 Genuine Stella
I don't think you have anything to worry about. I've owned three air cooled VWs. I live near Phoenix, AZ. I had to jet them a bit rich to help keep them cool, but they ran fine. I've used all kinds of air cooled 2 stroke landscape equipment out in 115F temps, and it just kept going. I don't ride or work in such intense heat anymore, not because the engines can't handle it, but because I can't.
@bluside avatar
2020 GTS 300, 2011 LX150ie
@bluside avatar
I'm in this camp living in Florida. The heat and humidity takes a lot of the fun out of it, (especially when you have to wear more than shorts, t shirts and sandals.)
I'm old. I've been riding a long time in all kinds of extremes. Nothing to prove anymore. My Miata, even with the top up and AC on comes in very handy.
@jakem avatar
Vespa Sprint Sport S 125cc
@jakem avatar
Vespas are designed and built in a country that commonly sees 40c+ summers (104f). I recently rode for 3 days in 37c (99f) and the Vespa was flawless (125cc Sprint).
As far as I'm aware, there's an engine driven fan - so even sat in traffic, there's still airflow to the engine.
Just make sure the oil level is correct.
@25bikez avatar
2009 Genuine Stella 2T (Sold). Helix Hunting.
@25bikez avatar
Yep.
When is it too hot for an air cooled engine? When I won't go for a ride.
with my gts I added a manual fan control for when the bike is heat soaked at the end of a long hot day and I'm struggling through traffic as I cross the city. This is because the ecu only turns on the fan when the bike is way above normal temp. Probably a bit unnecessary but gives peace of mind
A sign that an air cooled engine is overheating, is that they start to knock, usually while going up a hill.
Primavera 150
Primavera 150
I've thought about this too when riding in the summer. I think if you stay moving, you have nothing to worry about. You'll probably overheat before the engine will!
@jakem avatar
@jakem avatar
Has anyone on here actually had a modern air cooled engine overheat?
@jbacklund avatar
@jbacklund avatar
Every year during the Sturgis Rally, which is held in August, arguably the warmest month of the year in these parts, thousands of air-cooled Harleys clog up the town's main street and trundle stoplight-to-stoplight in a sluggish procession of 'duck walking' riders.
I often wonder how their bike's engines can survive this kind of torture, but I must admit that, considering the crazy numbers here for the rally, I don't see nearly as many broken down air-cooled bikes as one might expect.
@buggsy avatar
@buggsy avatar
Wish I could give you some advice on this subject, If it gets above 24c here where I live its hot Whew emoticon but short lived, we get plenty of rain and could tell you its not advisable to ride a scooter with an umbrella up ROFL emoticon
@juan_orhea avatar
S150 '09, Beo 500ie '08
@juan_orhea avatar
Air-cooled four-stroke small engine longevity - even in Chinese engines - is really quite impressive as long as the engine is kept oiled. You simply don't hear about many failing prematurely across lawn mowers, snow throwers, generators, Tao Taos, or Vespas. And when they do fail, I can't think of an example in which high ambient temperature was really a contributing factor.
Primavera 150
Primavera 150
Agreed. Not quite a scooter, but how many VW flat four engines were abused to extremes and kept on ticking for many thousands of miles? Looser tolerances, I suppose, allow for wide temperature swings.
@waspmike avatar
@waspmike avatar
What he said plus the idle speed on fan cooled engines is usually slightly higher to keep the fan working.
I frequently ride at 30C plus. Keep varying the speed.
[ Time: 0.0096s ][ Queries: 3 (0.0020s) ][ live ][ 339 ][ ThingOne ]
