I'm installing a new clutch cable but it doesn't engage the clutch whatsoever no matter how hard I tighten the inner wire.
So I suspect that the cable routing at the handlebar is incorrect.
I drove it out at the small window opening on the gear tube and into the headset through that oval hole and drove it down at the left side behind the clutch cables.
