Once the battery is in I'm going to investigate further but of all the searching I did online I can get a CDI anywhere from 150 to 250 oem. apparently the oem comes with 2keys or I can get an aftermarket one that gets rid of the immobilizer. For the life of me, I can't find where the cdi is on this bike, where are they?
I'm not fully convinced it's the cdi but what are some of the symptoms of the issue being the cdi?
this bike sat for 5yrs, so before I even start it up I'm going to change the oil, pump out any old fuel and refuel it, will look into changing the gear oil, what are other maintenance things I can do to this scooter as a diy-er? I can flush the coolant but honestly would rather let a shop work on that.
edit: just put the battery in, the scooter isn't recognizing that the killswitch is disengaged, no cranking over of the motor, just dead silence. what could be the issue there? will I need a new killswitch?
⚠️ Last edited by scooternj88 on UTC; edited 2 times
