I finished my LX project a while ago and did so much work to it and it was perfect, it then sat for 9 days which isn't as long as other times this year.
Anyway last night it wouldn't start at all just cranked and the green light was on, same for kickstart just the green light then it goes but no engine noise.
I've checked the throttle cable, air filter, battery, fuel tap, spark plug and checked for spark and they're all fine
Also took the fuel line off the carb and it seemed fine
I might take apart the carb to clean it but it's not likely because the spark plug is really wet, could also be flooded but I removed the plug and kicked and electric starter it loads of times with no luck
Any advice
