The engine management light keeps coming on while riding then going off when slowing down and stopping. Could someone shed some light on this please. Thanks
@safis avatar
@safis avatar
Could be overcharging from a bad regulator…
@wbdvt avatar
@wbdvt avatar
It would help to know the year, model, mileage of your scooter.
When you say engine management light, is this the check engine light?
Yes it's the check engine light On my 2010 GTS 250 with 18520 miles
@wbdvt avatar
@wbdvt avatar
ok, if the CEL is off at idle and then comes on when riding, most likely the VR.
Best way to confirm is with a voltmeter. Measure battery voltage with scoot off at battery terminals, should be 12.8V or a little higher
Start scoot and measure voltage, should be greater than 13V and less than 14V
Rev scoot to ~3k rpms, measure voltage. If goes higher than 15 or so, bad voltage regulator
Thanks for the info wbdvt👍
@wbdvt avatar
@wbdvt avatar
Report back on your findings
@buggsy avatar
@buggsy avatar
wbdvt's got it, I would do this test first to see if the voltage regulator's thrown a wobbly.
[ Time: 0.0104s ][ Queries: 3 (0.0036s) ][ live ][ 343 ][ ThingOne ]
