Thu, 14 Sep 2023 21:32:47 +0000
2005 et4
2005 et4
Thu, 14 Sep 2023 21:32:47 +0000 quote
Had to pull my carb to unplug a jet and had it sonic cleaned.
Thought we had reinstalled everything with same number of turns etc that it was set at when we pulled it out
Ran it but it was off. Pulled plug and it is totally black.
Anyone have the factory settings I can go to as a start.
Fri, 15 Sep 2023 16:18:04 +0000
LX150
LX150
Fri, 15 Sep 2023 16:18:04 +0000 quote
I don't believe there is an actual "factory setting" for this. I'd try seating it then backing off 2-2.5 turns and seeing how it runs. I'd also check the evap and ensure it isn't clogged. I think this carb runs noticeably better with a 38 jet, which is inexpensive. Good luck, and let us know how it goes. And ensure the manifold is in good condition.
Sat, 16 Sep 2023 02:28:32 +0000
2009 LX 150, 2008 GTS 250
Sat, 16 Sep 2023 02:28:32 +0000 quote
I saw reference to a separate brass bushing that goes in above the main jet. Probably to pilot the needle. Maybe this part was put in upside down?
Here is a good video to check out. It's for the GT200 but also applies to an LX150.
Sat, 16 Sep 2023 02:43:40 +0000
Sat, 16 Sep 2023 02:43:40 +0000 quote
how many turns out is the idle mix screw?
Sat, 16 Sep 2023 13:33:08 +0000
S150 '09, Beo 500ie '08
Sat, 16 Sep 2023 13:33:08 +0000 quote
You start with the screw 2 turns out, which is near the middle of the range of an acceptable end state of 1/2 to 3 1/2 turns out.
According to my notes, so I probably didn't write this originally (maybe Greasy did?): when you're done the screw should be set at least 1/2 turn out from fully seated, and no more than 3 turns out. If it is less than 1/2 turn out from fully seated when it runs best, you should install a smaller pilot jet and readjust. If it is more than 3 turns out, you should install a larger pilot jet and readjust. If the screw ends up more than around 3-1/2 turns out from fully seated, the spring tension on the screw is insufficient and there is a chance the screw can vibrate out.
(I have done many carb adjustments over the years and maybe I'm just dumb, but I always find it helpful to refer to specific instructions for each carb.)
By the way, on this carb a lot of people including me have been happy upping the low speed jet from the stock 35 size to 38. It costs ten bucks and takes five minutes once you have the carb out. Better idle and slightly better performance off the line.
(In other words…what JenniferJupiter already said!)
  DoubleGood Design
[ Time: 0.0233s ][ Queries: 4 (0.0021s) ][ Debug on ][ 286 ][ Thing Two ]
