@kawzak avatar
New 2023 BV-400
@kawzak avatar
New 2023 BV-400
Piaggio says monoethylene glycol coolant ( theirs-Oat or Goat?) and I'm good buying the OEM long life coolant. But some Vespa /Piaggio dealers have/sell/use other brands ( not sure why). My question is what brands/type are as good or better than the OEM coolant when it comes time to service/drain and refill. Thanks for your time.
@californiacruising avatar
2015 Sprint 150, 2018 GTS 300
There has been a couple good threads on this.
I bought the green Maxima Coolanol from Scooterwest last year because they were out of the OE pink, they said to flush system really good, don't mix different brands of coolant just in case.
In the future I will continue with the green Maxima Coolanol.
BUT if I had to do it over again I would've found some OE pink coolant and stuck with it every 2 years.
2017 GTS Super
2017 GTS Super
Not intending to be cheap I went with Maxima based on Scooterwest's recommendation. Pink's easier to see in the reservoir, Maxima's frugal even if you over fill. Keep close eye as you top up and a rag handy if you go green.
@kaptainkid avatar
2006 Vespa GT 200L
@kaptainkid avatar
2006 Vespa GT 200L
Is the Pink coolant the same as Automotive Toyota pink coolant?
@lars_danner avatar
2014 GTV300; 2009 S50
@lars_danner avatar
Yes.
@kawzak avatar
New 2023 BV-400
@kawzak avatar
New 2023 BV-400
And anyone know for sure what the shelf life of coolant is ?
[ Time: 0.0093s ][ Queries: 3 (0.0016s) ][ live ][ 334 ][ ThingOne ]
