Sun, 17 Sep 2023 20:02:20 +0000
2014 BV 350
2014 BV 350
Sun, 17 Sep 2023 20:02:20 +0000 quote
During the night, my bv 350 tipped over onto its left side. Would have been a soft landing, as it was parked in the yard. Rained a lot, figure the kickstand sunk into the dirt causing a tip over.
Started and ran as usual for 15 miles, then the fan kicked in. Stopped for a minute, re-started and the gages now didn't work. But the fan didn't come on. Couple more miles, turned off engine, then nothing when trying to restart. Pet carrier light comes on, but nothing else. Seems like the battery drained down. Checked battery connections, they are ok.
Any ideas while I wait for roadside assistance?
Sun, 17 Sep 2023 20:35:21 +0000
S150 '09, Beo 500ie '08
Sun, 17 Sep 2023 20:35:21 +0000 quote
You'll need to check each fuse, then chase voltages around with a multimeter to determine where the music is stopping. Is it possible the stator got wet while the scooter was on its side, and how the components are corroding?
Sun, 17 Sep 2023 21:21:13 +0000
2014 BV 350
2014 BV 350
Sun, 17 Sep 2023 21:21:13 +0000 quote
Was under a tarp, but the stator could have gotten wet. Battery is fine. Left brake switch may have been broken or disconnected, but wouldn't the right brake switch still work for start up?
Don't understand why it started and ran fine, then after 15 miles nothing. Makes me think something vibrated loose?
Sun, 17 Sep 2023 21:35:19 +0000
2020 piaggio liberty 150
Sun, 17 Sep 2023 21:35:19 +0000 quote
Kickstand safety kill switch? Spring on kickstand filled with dirt and not pulling kickstand back far enough to turn off safety?
Eliminate the simplest of things first. Could have also drained all of the fuel out of a vent?
The list goes on and on but as we compile the list we assign a rating of how simple to check and keep crossing stuff off the list until we find the cause.
Why is it whatever you are looking for is always in the last place you look? Because when you find it you quit looking. The only question is how long the journey will take and being calm and methodical while broken down roadside is a challenge.
Sun, 17 Sep 2023 21:58:44 +0000
Sun, 17 Sep 2023 21:58:44 +0000 quote
chipshot wrote:
…the gages now didn't work. But the fan didn't come on…then nothing when trying to restart. Pet carrier light comes on, but nothing else. Seems like the battery drained down. Checked battery connections, they are ok.
The gauges and dash lights would at least come on even if the kill switch or kickstand switch were faulty. Too bad the gauges don't work or the voltmeter display could be used to check the battery. I think that one or more cells in the battery may have failed, possibly caused by the tip over or the rain. The pet carrier light would work even if the battery were low.
Good luck!
Sun, 17 Sep 2023 22:02:14 +0000
2014 BV 350
2014 BV 350
Sun, 17 Sep 2023 22:02:14 +0000 quote
Battery tested fine. Otherwise all the symptoms of a dead battery, w the exception of the pet carrier light working. But for 15 miles it ran like usual.
Sun, 17 Sep 2023 22:04:17 +0000
Sun, 17 Sep 2023 22:04:17 +0000 quote
Have you checked all the fuses?
Sun, 17 Sep 2023 22:19:22 +0000
Sun, 17 Sep 2023 22:19:22 +0000 quote
Battery connection good no lights or gauges save pet carrier light must be fuse?
Moisture caused short?
Sun, 17 Sep 2023 22:58:22 +0000
2014 BV 350
2014 BV 350
Sun, 17 Sep 2023 22:58:22 +0000 quote
Like this one?
Thanks JKJ and skids.
Mon, 18 Sep 2023 14:17:33 +0000
2014 BV 350
2014 BV 350
Mon, 18 Sep 2023 14:17:33 +0000 quote
Found the blown fuse as the tow truck pulled up. I offered to walk to an AutoZone a little more than a mile away, but he suggested towing the scooter there in case a new fuse didn't fix the problem.
Well it did. For 15 miles anyway, when the dashboard went dead. Made sure not to turn the engine off till I got home. Then of course it would not restart. Back to troubleshooting. Does it make sense the problem is most likely behind the dashboard? That plastic is a pain to remove.
Mon, 18 Sep 2023 14:52:04 +0000
Mon, 18 Sep 2023 14:52:04 +0000 quote
Did the same fuse blow again? Which fuse was it?
Mon, 18 Sep 2023 14:57:56 +0000
Mon, 18 Sep 2023 14:57:56 +0000 quote
Could you tell us which fuse blew?
Mon, 18 Sep 2023 16:48:24 +0000
Mon, 18 Sep 2023 16:48:24 +0000 quote
When this happened to me the cause was a short in the wires that connected a third-party brake light flashing module. It had been stuffed into an area somewhat jankily.
The stock wiring on your scooter is PROBABLY pretty sound and well-protected from chafe. Add-on stuff might have gotten pinched in the tipover (or the tipover may have had nothing to do with it). Since your scooter died when the fuse blew, my first investigation would be anything that might have gotten patched into the ignition circuit - heated grips, USB outlet, etc.
Mon, 18 Sep 2023 17:30:27 +0000
2014 BV 350
2014 BV 350
Mon, 18 Sep 2023 17:30:27 +0000 quote
Fuse #5. Both times.
No add ons or mods on bike.
Gotta be caused by the tip over or moisture, I would think.
  DoubleGood Design
[ Time: 0.0263s ][ Queries: 6 (0.0029s) ][ Debug on ][ 286 ][ Thing Two ]
