Tue, 19 Sep 2023 02:01:24 +0000
GTS300 Super Sports
GTS300 Super Sports
Tue, 19 Sep 2023 02:01:24 +0000 quote
Hi
Just joined the forum and hoping to get a few answers. i just purchased the new 2023 model Vespa GTS 300 -great scooter apart from the continuous moaning and groaning it emits for a good 15 to 20 minutes from the time i turn it off to park.
Already I've had both neighbours question what is going on in my yard...and I have to tell them its my groaning scooter....lol
i've read that the EVAP system is the cause of that in earlier models. the answer pull it out and issue or problem solved.
The main issue i have not seen a clip or thread on pulling out the EVAP on a 2023. plus what parts to remove.
So if any-one can help or supply the odd photo what to remove-it would be greatly appreciated and thanks in advance.
Tue, 19 Sep 2023 03:17:05 +0000
Tue, 19 Sep 2023 03:17:05 +0000 quote
The one thing I can say to this is that this is seriously early in the bike's life to be having this issue. Unless it's suffered a tip-over at some point (which should be mitigated by the rollover valve, which it's there for), the EVAP shouldn't be giving you fits like this, but that's what seems to be happening. I'd be reluctant to yank the system off the bike on account of potential warranty issues, just for starters.
Tue, 19 Sep 2023 03:53:29 +0000
GTS300 Super Sports
GTS300 Super Sports
Tue, 19 Sep 2023 03:53:29 +0000 quote
That it is...lol I actually saw a guy on YOUTUBE have the very same issues on his 2022 model GTS and after he pulled the EVAP system -issue solved immediately.
It would be interesing if some of the 2023 scooter owners can chime in and mention if they have or have not this issue too or is it just a random thing.
I've never struck this one before on a new motorcycle or scooter.
Scooter runs well and great to ride in all areas. Well until one parks and turns it off. Then the moaning chorus starts within a minute or so.
I also flicked the seat up and released pressure in the tank via the cap. Seat made exactly the same sound too.
After one hour i pulled the seat again and it sounded very similar to what a car boot release sounded like or just noemal.
My thoughts being if i could pull that EVAP system out it could save me a 300 mile return trip to the dealer and another 300 miles to go and collect it again.
The 2023 model looks a bit different under the lid compared to a 2022 but i thought some-one here must know the answer on how to pull the EVAP.
Tue, 19 Sep 2023 06:06:12 +0000
Vespa GTS 300
Vespa GTS 300
Tue, 19 Sep 2023 06:06:12 +0000 quote
Property too small.
Tue, 19 Sep 2023 07:29:33 +0000
GTS300 Super Sports
GTS300 Super Sports
Tue, 19 Sep 2023 07:29:33 +0000 quote
Not sure...Never been to your house.....So i suppose it's quite possible.
Tue, 19 Sep 2023 07:44:04 +0000
2019 GTS300 Supertech E3 50,000km
Tue, 19 Sep 2023 07:44:04 +0000 quote
GermanGTSDriver wrote:
Property too small.
Less to maintain
Tue, 19 Sep 2023 12:49:32 +0000
GTS 300, Buddy 125
GTS 300, Buddy 125
Tue, 19 Sep 2023 12:49:32 +0000 quote
2023 GTS Super Sport, no moaning or other noises and I have on several occasions overfilled my tank which is when the evap will typically cause issues.
You can simply disconnect it and block the tube that would normally be connected with a small bolt or filter as some have done. Less drastic and reversible if you need to take in for warranty work.
Tue, 19 Sep 2023 12:59:21 +0000
GTS300 Super Sports
GTS300 Super Sports
Tue, 19 Sep 2023 12:59:21 +0000 quote
Thanks. So you have the exact model with the new front suspension link upgrade or over your way therey call it the HPE2 is that correct?
Tue, 19 Sep 2023 13:01:46 +0000
Vespa Sprint Sport S 125cc
Tue, 19 Sep 2023 13:01:46 +0000 quote
I'd be cautious of any potential engine warranty issues if you make changes. Are you filling the tank to the brim every time? And is the length of the sound related to the amount that you've ridden it - does a 1 hour ride generate the same noise, as a 10 minute ride?
Tue, 19 Sep 2023 13:07:00 +0000
Tue, 19 Sep 2023 13:07:00 +0000 quote
Don't think the Australian "2023" has the evap. (And they're not E5 either)
Tue, 19 Sep 2023 13:16:14 +0000
Tue, 19 Sep 2023 13:16:14 +0000 quote
Wildbill: Can you post a photo of your engine bay and point to the bit that's making the sound?
Tue, 19 Sep 2023 13:46:50 +0000
GTS300 Super Sports
GTS300 Super Sports
Tue, 19 Sep 2023 13:46:50 +0000 quote
Bike was filled up at the dealers and i rode it say 120 miles in total. Right from the start after every ride it gave that same horrible noise/bleat which went on for a good 15 to 20 minutes.
I've never experienced anything like this before and I review ALL my rides on YOUTUBE under RIDEWITHWARRO.
I'm in the process of doing reviews on this scoot now but its impossible to do a full out on the road on the spot review when for example today it bleated off 10 or 15 times in 10 minutes or once every 30 seconds...lol
I can imagine the subs listening to that and thinking a $13500 lemon when actually its a pretty good ride.
Even with this minor issue I still place it well ahead of the 2023 Honda Forza 350 and 2023 Yamaha Xmax 300 which I bought a year back and tested both back to back.
Now have the 2023 Xmax 300 which I plan to run against the Vespa GTS300 SuperSports.
Today I could not find the EVAP as shown on the superseded 2022 models. Looking at this scoot right below the petrol tank is a plastic cone type fitting and I think the sound is actually coming from it. Actually might be 2 of them.
This looks like just a fuel overflow line as it drops down towards front of motor.
I've been thinking maybe pulling the 4 screws surrounding the top of the tank and see whats behind there.
One thing I did notice from todays ride. Once home it started moaning within say one minute. I let it go for roughly 5 minutes as wife likes hearing it..lol thinks it funny.
So after the fun side i pulled the petrol cap and this time left it totally off for 10 minutes....no more noise!
Tue, 19 Sep 2023 14:13:08 +0000
Contributor
2007 LX 150 (memories)
Contributor
Tue, 19 Sep 2023 14:13:08 +0000 quote
From our WIKI:
FAQ: Why does my GTS groan/moan/moo or fart when off?
Tue, 19 Sep 2023 15:53:18 +0000
2020 piaggio liberty 150
Tue, 19 Sep 2023 15:53:18 +0000 quote
There are several times in recent history where vehicles have suffered from attempts at pollution control.
Don't get me wrong, I am not against pollution controls I just don't like to see them implemented only to cause problems.
An excellent example is my 1988 Jeep Wrangler with the 4.2 liter inline six. The early wranglers came with computer controlled Carter carburetors that also relied on a very complex vacuum system in order to comply with smog regulations in the late 80's and it was a disaster. The exact same engines of a decade earlier without all of the nonsense worked way better for much longer and were much easier to maintain.
The VW engineers were absolutely right to program the diesel vehicles to work one way for the test and another for real world driving. If it doesn't work in real world applications people will just find a way around it and the attempts end up wasting a lot of time and money for no progress.
I also have a 1994 Dodge ram 2500 with a 5.9 liter cummins diesel. It is two wheel drive regular cab with manual transmission and driven carefully will get 25 MPG. At 280,000 miles it still passes the smog test (I just got this one and it will get improved to do even better) and the only smog equipment it came with was a catalytic converter. If it did not have this it would fail the visual but the smog tech told me while it didn't pass the test with flying colors it did very well, not even close to failing. With careful tuning this vehicle will do even better emitting less smog and getting better mileage, I am hoping for 30 MPG in a heavy pickup which I think really good.
In some forums they prohibit discussing tuning of diesel engines as the forum owners don't want to be liable. I would hate to see our fine forum experience any repercussions for advising removing a mandated (CARB) system that causes the vehicles problems. Whatever you do don't ever just remove the evap system and plug the manifold port that feeds it to eliminate your scooter engine issues.
Tue, 19 Sep 2023 15:53:56 +0000
'23 300 Super
'23 300 Super
Tue, 19 Sep 2023 15:53:56 +0000 quote
I've got 33xx miles on my 2023 that i bought in april.
This has not been an issue at all for me....
Tue, 19 Sep 2023 15:57:08 +0000
'23 300 Super
'23 300 Super
Tue, 19 Sep 2023 15:57:08 +0000 quote
100%. even moreso since merc, bmw, dodge, ford, and chevrolet were *ALL* doing exactly the same thing, but when VW got caught they said "oh we weren't supposed to do that? oh gosh sorry we'll stop" and nobody cared. they had their pariah already everyone else got a pass.
Tue, 19 Sep 2023 16:18:02 +0000
2023 gts
2023 gts
Tue, 19 Sep 2023 16:18:02 +0000 quote
I have a 2023 Gts with about 1500 miles and no funny noises.
Tue, 19 Sep 2023 17:25:59 +0000
Tue, 19 Sep 2023 17:25:59 +0000 quote
I have a '15 which should be more in-line with the configuration being described in the Wiki. In my case, 8 years and nothing as described there has ever occurred with mine.
Tue, 19 Sep 2023 17:39:54 +0000
2022 Liberty 150S-"Meg"
Tue, 19 Sep 2023 17:39:54 +0000 quote
Both my GTs (a GT200 and a 300GTS) did this after riding, especially when the weather was warm. Comical and irritating, but completely benign.
No need to start pulling things off your bike that aren't broke, unless you just want to.
Tue, 19 Sep 2023 18:07:38 +0000
2005 GT200L: (-Jiffy5-) 2013 GTV300ie: (-RBBaron-) 2021 GTS 300 hpe
Tue, 19 Sep 2023 18:07:38 +0000 quote
Mooooo
https://www.youtube.com/watch?v=CN-SpMpxQUU
Tue, 19 Sep 2023 18:08:08 +0000
Vespa GTS 300
Vespa GTS 300
Tue, 19 Sep 2023 18:08:08 +0000 quote
I like the fart sounds. Makes me giggle.
My 2012 farted a lot, the 23 not at all.
Tue, 19 Sep 2023 22:57:47 +0000
Tue, 19 Sep 2023 22:57:47 +0000 quote
one of these? if so then it's not part of the evap
https://www.sip-scootershop.com/en/product/valve-piaggio-fuel-overfall_PI576748
Tue, 19 Sep 2023 23:09:39 +0000
GTS300 Super Sports
GTS300 Super Sports
Tue, 19 Sep 2023 23:09:39 +0000 quote
SteeleBytes
Thanks for the response. that is the item I felt and thought it may be the culprit. So I will check again later today after another test ride. I think there are 2 of them in total on that one line which winds it way to the front side of motor and centre stand area.
I'd say it could be just a overfill dump line. Not sure but will look into it.
Wed, 20 Sep 2023 05:13:36 +0000
GTS 300 HPE
GTS 300 HPE
Wed, 20 Sep 2023 05:13:36 +0000 quote
Has the scoot collected an Eastern Brown along the way...
https://pestpointers.com/sounds-and-noises-that-snakes-make-how-to-identify-them/
Wed, 20 Sep 2023 11:54:48 +0000
2022 GTS HPE
2022 GTS HPE
Wed, 20 Sep 2023 11:54:48 +0000 quote
This is the evap system off my 2022 GTS. Not only does it cause the farting noise but it can also cause you to get a check engine light after an overfill of gas. I just removed it completely.
  DoubleGood Design
[ Time: 0.0299s ][ Queries: 6 (0.0059s) ][ Debug on ][ 286 ][ Thing Two ]
