@derek_88 avatar
Vespa gt 125
@derek_88 avatar
Vespa gt 125
Hi I am rebuilding the engine mount and have found this part that I haven't ordered and forgotten where it goes 😅...I assume its a polybush...
⚠️ Last edited by Derek 88 on UTC; edited 1 time
@derek_88 avatar
Vespa gt 125
@derek_88 avatar
Vespa gt 125
Rest of the bits
@derek_88 avatar
Vespa gt 125
@derek_88 avatar
Vespa gt 125
More bits
@derek_88 avatar
Vespa gt 125
@derek_88 avatar
Vespa gt 125
More
@nitro200 avatar
2005 Vespa GT200
@nitro200 avatar
2005 Vespa GT200
Hi
This is just the job on my gt I need to do
Did you just get all the bits or did you get the mount as well ?
I'm having a little trouble figuring out what I need and also where did you purchase it ?
@derek_88 avatar
Vespa gt 125
@derek_88 avatar
Vespa gt 125
Hi the large bits have just all been cleaned and painted in smoothrite paint..everything else I bought from sip in Germany..yes pain in the arse to get everything and most places are out of the full repair kit..
@buggsy avatar
@buggsy avatar
Hi Derek, they are the nylon spacer bushes you can see them on this complete make up of the swinging arm cradle, sure they go on the metal spacers, if this does not help I've the three dimensional diagram with assembly instructions.
GTS/GTV swinging arm
@derek_88 avatar
Vespa gt 125
@derek_88 avatar
Vespa gt 125
Hi bugsy thanks for reply..so the black rubber in top pic goes between the white bearing cover and washer in lower pic brace..I only had 1 black rubber and no washers on inside lower brace..and can't find them on the sip explos...
@derek_88 avatar
Vespa gt 125
@derek_88 avatar
Vespa gt 125
Lol I just widened the picture and is that your finger pointing to the outside of brace where rubber should go.. ROFL emoticon
@buggsy avatar
@buggsy avatar
Sent you a private message mate.
@derek_88 avatar
Vespa gt 125
@derek_88 avatar
Vespa gt 125
Received..thanks again
@buggsy avatar
@buggsy avatar
There you go mate, hope this helps, marked what looks to be the part.
susp0
susp0
@buggsy avatar
@buggsy avatar
susp1
@buggsy avatar
@buggsy avatar
susp2
@derek_88 avatar
Vespa gt 125
@derek_88 avatar
Vespa gt 125
Brilliant thanks guys ..these will really help
[ Time: 0.0135s ][ Queries: 4 (0.0057s) ][ live ][ 339 ][ ThingOne ]
