Piaggio 1 active
Piaggio 1 active
Is there any information available about a recall for the ecu switch?
@germangtsdriver avatar
Vespa GTS 300
Vespa GTS 300
Please double-check:
- https://www.nhtsa.gov/
- check VIN with http://recall.piaggiogroup.com/default.aspx?BRAND=&LANG=EN
Note: Even if the Piaggio database does not show a recall for your VIN, that does not mean there is no recall. Only Piaggio or a dealer can confirm/exclude a recall based on the VIN.
- Call Vespa direct, and ask if your VIN is affected (and if yes if recall is done when vehicle is pre-owned)
https://www.vespa.com/us_EN/customer-care/
- And/or contact dealer to check your VIN
To make it clear: in general there are several "levels" of recalls
- official recalls
- safety related
- non-safety related
Depending on the level of issue there are different ways to communicate to customer and to solve the problem.
Primavera 150
Primavera 150
What's going on with them? I was looking at getting one for running around town on.
[ Time: 0.0086s ][ Queries: 3 (0.0025s) ][ live ][ 343 ][ ThingOne ]
