@mrnice13 avatar
Piaggio Fly 125 4T 07' / Piaggio Typhoon HiPer2 02'
@mrnice13 avatar
So I just buy a diaphragm and the slide for the worn one that I have.
I just want to know if the rubber need to stick in the groove because I can't hold it and put the cap on at the same time. Its better with the new one but I still have a little hole in the upper range when I go WOT I wonder if it's the accelerator pump.
Thanks boys
@mrnice13 avatar
@mrnice13 avatar
Wonder if I can mount the Naraku one from and make it run good. Motovista said that you can make it run with it but not perfectly.
@berto avatar
@berto avatar
Thanks boys
Yes, the diaphragm needs to seat fully in the groove. Sometimes a light smear of grease can help hold it in place whole you put the top on.
@mrnice13 avatar
@mrnice13 avatar
I'm going to recheck the diaphragm positioning today. What kind of grease I can use for this
Gt200 2003
Gt200 2003
Hold the outer lip if the diaphragm in place usi g red rubber grease😎
[ Time: 0.0126s ][ Queries: 4 (0.0040s) ][ live ][ 318 ][ ThingOne ]
