@redpanda avatar
Red Vespa Primavera 150
@redpanda avatar
Hey Everyone,
I'm looking at a Primavera 150 and the seat is too high for me (I'm 4'11 1/2") Anyone have experience with lowering their vespa with a lowering link and/or shaving the seat down? I thought they used to have low profile seats and apparently not anymore.
@jakem avatar
Vespa Sprint Sport S 125cc
@jakem avatar
Have you been looking at the GTS or the Sprint / Primavera?
It is possible to buy a small metal part that lowers the Vespa itself.
Have you tried sitting on one so far? The further forward you sit, the easier it is to put your feet flat on the ground.
@abner_bjorn avatar
@abner_bjorn avatar
I just did this to my BV250. I was after more comfort, but ended up dropping the front seat height by almost 2"
Before
Before
After
After
@shedwyn avatar
2007 GT 200
@shedwyn avatar
2007 GT 200
I am 4'11" and I bought a pair of demonia brand platform boots (3") which helped a lot. I read mixed messages when shopping for a scooter about lowering options.
I bought a used GT200, so it feels like a lot of scooter on top of being tall.
@spacedog avatar
2005 GT200L: (-Jiffy5-) 2013 GTV300ie, 2021 GTS 300hpe
@spacedog avatar
This wiki on suspension preload might help too.
https://modernvespa.com/forum/wiki-proper-way-to-adjust-shock-preload
@besupa avatar
@besupa avatar
My partner is in the lower five, but has a relatively short inseam, so her experience might be of use to you.
I had a Sprint 150 with, first, just a lowering link. Once the electrical issues it caused were sorted, it served well enough, but had a noticeably rougher ride for obvious reasons. While higher heeled shoes and thicker soles made a difference, it was still too high for her to feel fully comfortable.
I lucked into buying a Corbin lowered seat and that helped a lot more with making contact with the ground and being comfortable at stops. They can be pricey, but worth it if it suits you. Also, it was a more comfortable seat than stock overall and I preferred it for longer rides (although I would prefer sitting on the pillion seat on stock for short rides).
Overall, both were needed to make it work. If I had to choose just one, I'd start with the seat mod as it's more comfortable anyways and the shape and forward bias to the curve of the seat had other benefits for making contact with the ground.
A lucky shot in profile during a turn.
@adri avatar
Atypical Canadian
Atypical Canadian
@adri avatar
Wait, what?
@redpanda avatar
@redpanda avatar
Hi Everybody, Your replies are super helpful! I am new here and not sure how to reply individually and wanted to thank everyone for sharing their ideas, links, and experience with this.
I am looking at the Primavera 150. I'll look into the riding boots and shaving the seat first based on the replies. Then worst case scenario, I can get the lowering link installed.
And yeah my inseam is 24" so all your tips really help. Thank you! 😊
@besupa avatar
@besupa avatar
besupa wrote:
Once the electrical issues it caused were sorted, it served well enough…
adri wrote:
Wait, what?
This was some time ago and I didn't do the work myself, so I can't really answer definitively as to what happened. From memory, the way they routed the wiring after getting in there ended up getting pinched or jarred, eventually leading to the rear lights going out. Apparently obvious after the fact and they routed differently, but a thing that happened as a consequence of the change that had to be sorted, oops or not.
No problem. There is a "quote" button hiding in the upper-right corner of each post. It's gray on gray, so kind of blends into the background. Press that and it will copy the post into a reply (with quote tags applied). You can then delete the bits of their post that aren't germane to the conversation, add your reply below the ending quote tag, and bob's your uncle.
@redpanda avatar
@redpanda avatar
Found it! Thank you Jess
[ Time: 0.0085s ][ Queries: 4 (0.0022s) ][ live ][ 339 ][ ThingOne ]
