Hi,
New to Vespa, just picked up a PK125XL elestart a week ago and it's been super fun to bop about on but I have a few issues.
One of those is that after letting of the gas at high revs it hangs and won't go come down unless I break the engine speed with clutch+breaks. It will rev up super high or just give me undesired cruise control at random times. It's not 100% of the time but it is most of the time.
I suspect a vacuum leak as I can't get the throttle to stick up no matter what I try.
Checking the plug it seems somewhere on the edge of too lean, it is a perfect brown-bronze on one side and slightly pitted and black on the other.
Pulled the carb and checked the jets, what I belive is the main reads 80, the other one in the bowl reads 60(is this the choke jet?) and the one that screws in from the side reads 55. These seem suuuuper rich compared to what the normal PK125 has from what I found online, but I could not find anything on the XL.
I suspect the intake manifold gasket is the culprit and the rich jets feed the issue further but I'd like to hear from someone who has worked more with these engines before I start the whole procedure to get the intake manifold off
