@kawzak avatar
New 2023 BV-400
@kawzak avatar
New 2023 BV-400
Have you had to return to dealer after purchasing a new BV 400 to get any software updates/upgrades even if it was months or more after the purchase ? Thanks for any replies.
Vespa GTS 300
Vespa GTS 300
Every modern vehicle gets software updates from time to time. These can be minimal adjustments, improvements or even bug fixes. As a rule, such updates are made during regular service intervals or other workshop visits without the customer noticing. Piaggio uses a proprietary, closed system for this: P.A.D.S., In addition, in individual cases there MAY be officially ordered or voluntary recalls by the manufacturer.
Software updates are not equal to a recall (and vice versa), but there are recalls that are done with a software update.
Note: Softwareupdates (when they are not a recall) are only visible if dealer connect vehicle with PADS for diagnose!)
Note: "Recall" in this context does not necessarily mean an unscheduled workshop visit, especially in the case of software updates it often means "at the next opportunity" (i.e. next scheduled workshop visit).
To check if there are "Recalls" for your vehicle, please double-check (But only dealer will be able to determine software updates beyond recalls while connecting vehicle to PADS!):
- https://www.nhtsa.gov/
- check VIN with http://recall.piaggiogroup.com/default.aspx?BRAND=&LANG=EN
Note: Even if the Piaggio database does not show a recall for your VIN, that does not mean there is no recall. Only Piaggio or a dealer can confirm/exclude a recall based on the VIN.
- Call Vespa direct, and ask if your VIN is affected (and if yes if recall is done when vehicle is pre-owned)
https://www.vespa.com/us_EN/customer-care/
- And/or contact dealer to check your VIN
To make it clear:
- in general there are several "levels" of recalls (e.g. official recalls, safety related, non-safety related, etc) -> Depending on the level of issue there are different ways to communicate to customer and to solve the problem.
Quintessence: Visit your dealer and check for recals and/or software updates.
@cdwise avatar
GTS 300, Buddy 125
@cdwise avatar
GTS 300, Buddy 125
I don't know if it is a "required" recall but I know at least one software update was done on my 2023 GRS Super Sport when it went in for service. Since the update it has connected to the app flawlessly every time. Before that I could connect the scoot but had not been able to reliably connect the app so I'm assuming it was a bug fix in the Bluetooth connectivity module at least.
Piaggio Beverly 300s
Yes, there have definitely been updates to the PMP3 bluetooth module since initial release for the GTS. would expect similar for others of the same age
BV400
BV400
Fwiw, when I had my 2024 bv400 in to get my key fobs duplicated last month, the service guys were forced by the software to update the scooter firmware before it would allow the key duplication to proceed.
[ Time: 0.0106s ][ Queries: 3 (0.0016s) ][ live ][ 335 ][ ThingOne ]
