Hi,
A coupple of days into owning my PK125XL the rear started making a squeal under light breaking along with pulsing. Is there any chance that it is just the pads or will the entire drum need to be replaced? There is a slight oil leak from somewhere i havent found, could that be the cause of this somehow?
What other parts than just the drum and shoes would i need or are wear items that should be changed at the same time?
