PX 2006 ignition/lock barrel removal - Is it really just a matter of removing the horn cover turning the ignition to the on position and then fettling a small pointy object into a hole on the barrel sleeve behind the horn cover to depress a spring clip and the barrel slides out? Thanks
All Content Copyright 2005-2025 by Modern Vespa. All Rights Reserved.
