Vespa GTS 300 2023
Vespa GTS 300 2023
Hi there,
My local motorbike store wants to install the Brembo calliper on my 2023 GTS together with a Zeloni brake disc.
They've orderderd this mount:
https://falanparts.com/collections/gts-brakes/products/adaptor-zelioni-brembo-brake-calliper-front-vespa-gts-models-125-300cc-14
Altough it says from model '14- and newer it is untill '22 model.
Anyone else knows something about this....? It doesn't fit. Is there a '23 model?
I did came across: https://www.instagram.com/p/Ct006SZvOmN/
but I'm not sure this is what I am looking for and if its shipping to the Netherlands.
thanks!
to my understanding you are correct.
the zelioni (and similar brands) adapter the store wants to use apparently won't work with a 2023 gts. (I don't have a 2023 or that adapter so can't verify with my own eyeballs).
the only solution i've seen is replacing the complete bottom bracket and using a different calliper as shown in the instagram post from jsmanuf or 101factory or marus etc.
bracket for Brembo brake mounting on GTS '2023'
PS you could let the store try as long as they agree to refund you for all parts and labor if they get halfway through and find it doesn't fit.
[ Time: 0.0108s ][ Queries: 3 (0.0036s) ][ live ][ 339 ][ ThingOne ]
