125 gts 2009
125 gts 2009
any1 got a solution gts 125 with left hand incators stuck on
@jkj-fz6 avatar
@jkj-fz6 avatar
Faulty switch?
@crazycarl avatar
@crazycarl avatar
Definitely need to pull the switch to inspect and at least clean it up.
Likely you'll need to replace it though if the push to cancel is broken.
2019 GTS 300 HPE SuperTech 72,000km
remove the switch and test the contacts with the multimeter while switching it to each position and pressing centre to cancel
[ Time: 0.0333s ][ Queries: 3 (0.0196s) ][ live ][ 334 ][ ThingOne ]
