Does anyone know the correct name for the flat square clips that hold the bezel in place on a GTS 300, and how to remove them? I'm thinking that I can pry them up the small post to remove. Thanks in advance...
![]() GTS300 Super (Mustard) GTS250 Super (Bulger)
Posts: 5063 Location: Tempe, AZ |
thanks, I figured it must be a non US type fastener, I will check the internet for the removal tool....
![]() GTV / GTS, 1961 Lambretta LI Series 3
Posts: 537 Location: Somewhere on the Island of Great Britain, East Coast, Last time I looked. |
BUGGSY wrote: U Clip, is this what you mean. removed with trim, hook and pick set. |
Are you asking about the clips that hold the bezel that surrounds the instrument cluster? If so, they can be popped off with a jewelers screwdriver. A 5 mm socket will press them back in place. The VHB adhesive tape under the bezel can be softened with a hair dryer so you can pry the bezel up enough to use a razor blade to slice through the tape.
Edit: Looked at my invoice, Scooterwest describes the part as a "PLATE BADGE CLIP (D3 X 3)." |
Right those are standard Flat Rectangular Push On Clips, there are also starlock clips or flower clips that basically do the same job, these are commonly only a one shot clip thrown away and a new one used you can get packs of them for a little price, but you still need a hook and pick set to remove them.
Cheers. |
