Hello there I am new to the blog.
I would like to ask you a question if I might!
My Piaggio x9 500 will not flash the balbs of the injection, the alarm, the run/stop , and the low / high beam on the digital dashboard when I turn on the key, so I can check if all the lamps are working.
Still I cannot reset the analog clocks althought they are working perfectly. Everything else is checking fine.
Do you have any idea about that?
I have this problem for so many years.... I have visited many Piaggio workshops and nobody solved my problem.
I would appreciate if you could help me.
Thank you in advance.
Anthony
