1981 Vespa P200e, 1985 Vespa PX125e, 1985 T5, 1971 Sprint Veloce
Hey all. Any tips or trick on how to remove a t5 front fender. All hardware has been removed and the fender moves freely however I cannot seem to manipulate the fender over the steering blocks or bottom race of steering bearing.
Any suggestions?
Thank you.
N
@safis avatar
@safis avatar
Stupid question but I assume the fork's out?? Twist it at an angle to first clear the "end" block and then do the same to pass the bottom bearing…
Yes. The fork is out. Hahaha. Imagine if it wasn't?
I tried manipulating snd turning the fender to get it over the obstacles. But no dice.
@safis avatar
@safis avatar
It's a bit tricky. Went down to the garage. Although it's a plastic PX mudguard (thicker) you get the idea...
https://youtu.be/NNNUf3qMdpQ
@markosmarkos avatar
A few fenders I have had couldn't clear the lower metal dust shield. The lower bearing race had to come off, then the dust shield, then the fender could be removed.
Major PITA.
But if it clears like Safis' shows, you are golden.
@safis avatar
@safis avatar
Really strange. Never had to remove the bottom bearing even on the newer models...
I hope it's as easy as safis makes it look.
I really don't want to remove that bottom race.
Major PITA.
Can't remove the fender on a VNA/VNB without removing the dust shield and race. Such a pain in the butt.
Hey everyone. Thanks for your replies. After watching the video demonstration above, I was able to remove the fender.
Thanks again.
Cheers.
[ Time: 0.0099s ][ Queries: 4 (0.0022s) ][ live ][ 334 ][ ThingOne ]
