Wed, 11 Oct 2023 05:58:45 +0000
mp3 250ie 2007
mp3 250ie 2007
Wed, 11 Oct 2023 05:58:45 +0000 quote
Hi all i just need some help on why my Piaggio mp3 is draining my battery
if i leave the bike and start it up its fine but after a journey out to work it just dies
if i stop at a garage to get petrol it wont start because the battery has been approx 20miles. drained. during the ride to work i notice the lack of power and then the indicators die and then the bike turns off. if i fit another charged battery then its fine for another 20miles
I have already fitted a new solenoid and regulator rectifier and spark plug + lead
really not sure what else ?
Wed, 11 Oct 2023 07:08:23 +0000
2009 mp3
2009 mp3
Wed, 11 Oct 2023 07:08:23 +0000 quote
You really need to stick an AC volt meter on 2 of the 3 three supply wires from the stator which plug into the regulator rev it up and check the voltage. It should be some where between 30 to 40 volts. if it doesn'"give you that value the stator might be bugared or the connections to the stator have gone faulty.
Sounds like you have already had the plastics off on the right side to replace the
regulator and it will be much quicker the second time around.
Thu, 12 Oct 2023 15:42:55 +0000
mp3 250ie 2007
mp3 250ie 2007
Thu, 12 Oct 2023 15:42:55 +0000 quote
Hello so i tested the battery its showing 12.2 and when revving the bike past 4k rpm it just sits at 12.2 when i turn on the indicators and light it goes to 12.1 it does not seem to go up when revving
Thu, 12 Oct 2023 18:30:24 +0000
2009 mp3
2009 mp3
Thu, 12 Oct 2023 18:30:24 +0000 quote
As I mentioned in my earlier post check the output from the stator.
Thu, 12 Oct 2023 19:19:37 +0000
Gilera Fuoco 500ie
Gilera Fuoco 500ie
Thu, 12 Oct 2023 19:19:37 +0000 quote
a fuse , flywheel bearing or voltage regulator
Fri, 13 Oct 2023 10:12:42 +0000
mp3 250ie 2007
mp3 250ie 2007
Fri, 13 Oct 2023 10:12:42 +0000 quote
hello guys ps oldgoat sorry i am not a expect using a voltmeter
i have tested the voltage regulator as i have 2 of them both are working as i don't see the voltage go above 14-16v i noticed i have a burnt (melted) 30amp fuse that connects to the voltage regulator (fuse still worked)apparently. i also noticed tons of extra parts added to the bike ie a alarm system and 3x speakers for the indicators and alarm audio i have removed all these extra stuff and hope this might of been the issue drawing to much power from the battery i also notice the guy was wireing up heated grips.
Sat, 14 Oct 2023 16:53:09 +0000
mp3 250ie 2007
mp3 250ie 2007
Sat, 14 Oct 2023 16:53:09 +0000 quote
hi guys if you are interested i found the issue and its an odd one
i found the owner before be fitted an alarms system and 3x speakers 1 for the indicators to beep 2 for an audio voice when the alarm is on and 3 i don't know the 3rd one and i can see wiring for heated grips i have take all this out and i can confirm the battery is how holding charge at 13v and its stable. thank you for all the help.
  DoubleGood Design
[ Time: 0.0269s ][ Queries: 3 (0.0061s) ][ Debug on ][ 298 ][ Thing Two ]
