@boraxman avatar
GTS250
@boraxman avatar
GTS250
Last Saturday I was able to get a good first multi-mile ride in since putting in a 300 engine and big work on the wiring harness.
I went to leave my last destination after the scooter sat a couple hours and as I was turning it over it started spewing gas all over the ground,
Checking it out I found the gas feed line popped off the top of the fuel pump.
I was able to pop it back on but inadvertently disconnected the power connection right behind it and ended up having a buddy tow it home.
Im wondering what happened here and if anyone else experienced anything like it. Looking at the tabs the fitting snaps into, they look fine.
Kinda nervous this could happen again even while riding...
@greasy125 avatar
@greasy125 avatar
I've had the similar thing happen. as best I could tell the plastic had stretched/fatigued or taken a set with age and heat cycles and the new connector wasn't a perfect fit leading to the same outcome.
I used a heat gun to soften up the connector a little and "adjust" it to put a little more bite in the connection.
@kaptainkid avatar
2006 Vespa GT 200L
@kaptainkid avatar
2006 Vespa GT 200L
So she is running good now? Besides the minor parts issue.
@boraxman avatar
GTS250
@boraxman avatar
GTS250
Running great but freaking broke my fuel injector.. New one should be in tomorrow
@kaptainkid avatar
2006 Vespa GT 200L
@kaptainkid avatar
2006 Vespa GT 200L
Did it bottom out and FI hit the pet carrier and snap?
That's a common problem with large body Vespa.
@boraxman avatar
GTS250
@boraxman avatar
GTS250
I think it bottomed out while I was dropping my fuel tank trying to see what was going on, broke my shock at the same time, heard the injector crack.. Was in too muck of a hurry. Lesson learned.
[ Time: 0.0097s ][ Queries: 3 (0.0023s) ][ live ][ 335 ][ ThingOne ]
