2004 ET2
2004 ET2
Having now taken apart my Weber 12 carb and cleaning all parts (twice) i am officially giving up on reconditioning it. Still doesnt want to start up.
Time to bite The bullet and replace with a new carb.....but which one should i order? Want a plug and play solution including The necessary Electric choke. Suggestions? China copy or Dellorto or similar
@safis avatar
@safis avatar
2004 ET2
2004 ET2
Cheers....not cheap mind!
Having scoured The Internet regarding The Delly 17,5 carb it seems it is not a plug and play replacement since The vacuum tube entry is plugged with a brass plug which requires drilling before you are able to attach The vacuum tube from The petcock...
[ Time: 0.0082s ][ Queries: 3 (0.0015s) ][ live ][ 334 ][ ThingOne ]
