Letmein wrote:
Is it worth it or replace rim. I know they are staked. So do I just grind down the threaded side and pound out? Also... What makes a rim warp and not flush when screwed together. I'm on my spare and it's not flush.thanks!
Don't punch. They're threaded in.
Do you have enough left of the stud to weld a nut onto it?
If so, drive the stud in just enough to dremel/grind off the staked material and then back it out.
If not, it can be carefully drilled out with a 6.8mm carbide bit using a drill press, then run through with an 8mm tap.
Replace all of them (by double nutting) while you're at it.
Most stubborn stud replacement:
